| Zero Cool |
I was at a swap meet this weekend and picked up a "Tube God TH-1 Amp Regulator" PCB, fully loaded but never used. It has the numbers 9-82 which i assume to me Sept. 1982. But i have no idea what amp this is for???
It has solder pads for In/Out/Gnd and has 2 RCA 7819 and 1 RCA 7815 TO-3 Devices plus a LM10CH and a 2N3439 as well as a TIP50 on board.
If anyone knows what this is or has any DOCS, or any interest in it. please let me know.
ZC |
| Zero Cool |
| WOW, no one knows anythig about this??? Thats amazing! |
| ErikdeBest |
| can you post a picture...you know, it speaks for thousand words. |
| arnoldc |
Based on the parts you mentioned, this is a regulator board for (maybe) filaments and high voltage. The LM10CH is an opamp voltage reference which may be controlling the 2N3439 to deliver the high voltage, probably 300-350V range. The TIP50 can deliver up to 500V I suppose.
This board for a power amp project as the name implies.
If this has been made in 1982 by some small company, or a person, it won't be known for many. |
| ken.berg |
| For what it's worth, "Tube God" was the name that Harvey "Gizmo" Rosenberg did business under before he started NYAL. This looks very much like his workmanship. |
| Zero Cool |
| quote: | Originally posted by ken.berg
Ahhh Now were getting someplace!
This must be a single voltage regulator as i only see one input/ground/output labels. |
| Brian Beck |
| If this is Harvey's workmanship, please swab it for traces of Harvey's DNA. Save that sample for the day when cloning humans becomes practical. The world needs more exuberant Harveys ;) |
