diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Jensen - unusual cap. - Click HERE for Original Thread
lndm
Came across this, it has a single value written on the case but has three leads (had to fix the scan).
I'd like to know what it is if anyone knows?
Elso Kwak
just look at the site of Jensen:cool:
lndm
I've looked at dozens of sites including Jensencapacitors, but no info on these.
Nigel Goodwin
From the value it looks like a motor starter capacitor, or something similar?. If you check the connections I'm presuming either two of them will be connected together, or one won't be connected at all - the three connections are used just for mechanical stability when mounted.
lndm
Hmm, plausible. BTW the case is 1 5/8" long. My research tells me so far that other mixed dielectric caps are paper and polypropylene.
Elso Kwak
http://www.partsconnexion.com/jensen/jensen.html
commsysman
that may be a dual capacitor with two sections and a common negative or ground connection....
lndm
quote:
Yes, I measure 3u3 across two terminals only, and open circuit across all.
Page generated in 0.021958112716675 seconds with 17 queries,
spending 0.00770950 doing MySQL queries and 0.01424861 doing PHP things.
Please support our sponsor.
