diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Music
low bass CD suggestions ( <20Hz) - Click HERE for Original Thread
sphinx
Can anyone recommend any CDs with bass information below 20Hz?
I do already have all the low bass Telarcs (1812, Toccata and Fugue, Porgy&Bess). Not interested in car audio synthesized bass... I'm looking for the real thing!
Thanks...
lndm
That Toccata and Fugue Telarc is really something isn't it? Was just listening to it the other day.
It's been a while since I read this, but I think the cd standard cuts off at 20Hz?
phase_accurate
There are two CDs with movie soundtracks conducted by Erich Kunzel (also Telarc) that contain several sequences going down to 5 Hz. One one of them is the start of a space shuttle used as intermission. Now THAT is a broadband signal !
The name of one of those CDs is "The big picture" the other one I'd have to check first.
And there are also some test CD's by the Swiss Highend Society. One piece that goes down to 16 Hz is the following:
http://www.swisshighend.ch/AudioFil...ons/track13.mp3
BTW: If your system is going below 20 Hz you do not necessarily have to feed it such extreme program material in order to enjoy it. Stuff like Eric Clapton's "unplugged" greatly profits form systems that are going really low even though there is no "real" content down there.
Charles
Valvewizard
Maybe Jim Brock- tropic affair
Zero Cool
Grace Jones Slave to the Rythm has a track with a sub sonic note in a couple of spots. not sure if its really supposed to be there as is down around 5 hz. MOST cd players will not even reproduce it. but a few will.
I discovered this purley by accident many years ago. I had just purchased a JBL B460 Subwoofer. a BIG 18" sub in a 8cu/ft cabinet. I was using 1200watt bridged mono amp to run the sub and i had just got everything hooked up and played my favorite track off the cd. a everything was working ok so i turned up the volume and just as i did. the WHOLE FLOOR in my apartment felt as if it was moving up and down. i looked over and the cone and it was moving huge amounts of air but i couldnt hear anything, i looked over at the amp and the meters are pegged! and just as i reached for the volume control to turn it down. it went away! scared the bejezus out of me!
So im checking all my connections and everything is working and seems ok so i grab the volume control again. everythiong still working fine and then BBRBRBRBRBBRBRBBRBBR it happens again. so this time i turn down the volume and rewind the track a bit and sure enough in two spots there is something there. really really low.
I sold that sub long ago but but even with my Hales Revelation 3's i can hear or maybe i should say feel it in the same spots. but at a MUCH lower level.
sphinx
Zero Cool, Yes I do have Grace and I the CD does have some impressive low end..makes for a great demo.
Valvewizard, I will give Jim Brock- tropic affair a try!
Charles, The Telarc Star Tracks CD (has the same track as the one you're referring to )does have some very low frequency content but some of it sounds like a kid created it on his PC...I much more enjoy the tracks with "natural" bass but that CD is still a good demo. I'll see if I can find the Swiss over here.
lndm, I love the Toccata and Fugue Telarc...I could bounce my remote controls off my coffee table with that track. Most mid to high end CD players are capable of producing output down to 5Hz. I used a spectrum analyzer to confirm this...Telarc 1812: significant output down at 8Hz. Of course that's to be expected because those cannon shots are probably about as close to a "perfect" impulse response as one can naturally record (not including digitially created)!
karlw
Check out "Holst - The Planets" by Montreal Symphony. This is a 1980s recording. But I think it is in the "Jupiter" part, there is some kind of organ pedal note that just shakes the house, even with smaller speakers. Must sound insane on a larger system.
-Karl
Ric_LV
I have a keyboard at home and I can record low tones for you. When I select a blues organ and play the lowest note all I can see is that my subwoofer's speakers are just moving (very rapidly - huge excursion!) but I can barely hear a sound. I actually just feel it... I don't know if you will ever find a natural sound under 20 Hz, not from a music instrument. You'll only find unnatural sound from a digital source, like keyboard.
jives11
Some recordings made in the Kingsway hall in London have some extremely low notes generated by the Tube trains operating 50' underground. Quite a few DECCA's I have include this feature.
Q: How low does CD go though ? I thought it didn't go lower than 20Hz or higher than 20Khz
4fun
The CD standard permits bandwith down to DC.
On CD players often have HP filter implemented to eliminate risk of putting constant DC to amplifier.
Look at spec on CD player, they often have bandwith down to 5-10Hz. Lower cutoff also depends on input imput impedance of aftercoming amplifier.
Some CD players have DC connected stages but instead have DC servo that need some kind of cutoff freq to be able to center output to DC in resonable time. Of course it is possible to have much lower cutoff with less cap value this way.
It is also possible to make stages DC connected without DC servo and have true respose down to DC but there is probably need for manual DC trim if not tolererating some constant small DC on output.
cogsncogs
44.1kHz = 20.5kHz upper limit.
To get nice numbers: Frequency response = 20-20kHz +/- 0.1db.
Most CD players have a rated bandwidth down to 2 - 4Hz.
Bandwidth may read something like this 2-20kHz +/- several db's.
Wayne
gfinlayson
I've run the test tones CD from realtraps.com to measure room nodes. The tones start at 10 Hz, and my CD player reproduces 10 Hz comfortably. So do my speakers :D
sphinx
my speakers reproduce 0.5Hz comfortably ... :bigeyes:
at a 50 dB SPL, 80% THD, Mic at 0.0000001" :D
Albertb
Pan pipes of the Andes LP has a quiet track which includes a section recorded at altitude in the mountains of a sudden thunderstorm. The bass is awesome.
Page generated in 0.036617040634155 seconds with 17 queries,
spending 0.00827670 doing MySQL queries and 0.02834034 doing PHP things.
