| staticvoid |
will this work with the Ushio S400DD (HPS Retrofit) bulb?
400 hp mt ballast
approp. voltage
120v 3.90a
208v 2.25a
240v 1.96a
277v 1.70a
lbf2-2969
catalog no. lp2a400hpmt halaphane
there are 10 wires coming from the coil 2 are hooked to the cap. 3 are hooked to the starter
rest are as labeled as follows
1. 120
2. 208
3. 240
4. 277
last wire i cant read its a dark bluish green wire
im trying to use it on 120v i assume i use the 120v line and cap the others, and maybe use the darker color as the neutral? |
