diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
Hypex Active Home 2-way amps - Click HERE for Original Thread
CDubber
I bought a couple of these amps directly from Hypex in The Netherlands a while back for testing for a potential project. The project never got off the ground, and the amps were never used. I have two. One has been opened but unused, the other is unopened.
Specs:
2x80W/4Ohm
120W max. total power
Linkwitz-Riley
Make me an offer on one or both. I paid around $150 for each new. Thanks!
BenY
Is this set totals 4 channels, two channels for each side with an integrated crossover per side ???
If that`s the case then I`m interested...
Thanks,
Yuval.
CDubber
Hi Yuval,
I have no real audio technical knowledge, but you can see more detailed specifications for the amp here:
http://www.hypex.nl/products/AH/AH.htm
kestrel200
So do these come with the crossover "modules" if so waht are they?
Spiritzly
I tried to email you but couldn't. Please email me: audioexcels@yahoo.com
Thanks!
CDubber
quote:
Not having any experience in this, I'm not entirely sure what I'm looking for, but there is a module on the amp labeled "2500 Hz" marked "Filter High/Mid" on the circuit board, which I think is what you may be referring to.
john65b
Where are you in Utah...I live in Draper and work at the Noth end of SLC...
CDubber
quote:
South Weber, just north of Layton.
CDubber
** bump **
Page generated in 0.025469064712524 seconds with 17 queries,
spending 0.00791430 doing MySQL queries and 0.01755476 doing PHP things.
Please support our sponsor.
