diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > ESLs, planars, alternative technologies
Yet another DIY ribbon thread - Click HERE for Original Thread
Puggie
Started with an old magnet from a ribbon mic so its only 1/4" wide. the ribbon is finest KitKat wrapper and I'm quite pleased with the result, playing full range it sound pretty good from about 300Hz up (ribbon being driver directly from an amp).
how do I go about getting higher SPL, bigger ribbon? which means new magnets.
bigwill
How are you driving the ribbon? With a transformer or directly?
Puggie
Directly off a A&R (old Arcam) A60, it claims to only be 8Ohm stable but isn't overheating (the speaker outs are fused too).
I need to look into transformers next.
tomtt
what might the DCR be on this?
Puggie
quote:
pretty much nothing, well under an ohm, its a bit of thin aluminium foil, 1/4"X2 1/2".
Page generated in 0.020569086074829 seconds with 17 queries,
spending 0.00918627 doing MySQL queries and 0.01138282 doing PHP things.
