diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
high gain 2nd order high pass active filter topology - Click HERE for Original Thread
sreten
A question for experts on active filters.
Can a single op-amp be configured for gain ~ 30dB
and also provide a 2nd order high pass function ?
All topologies I've seen have limited gain.
:)/sreten.
AndrewT
just a guess but maybe an MFB might be able to reach up there.
Remember to check your gain bandwidth requirement for the opamp for that extremely high gain.
darkfenriz
I'm not sure (I am no expert) but I would use an 'undercompensated' opamp like op-37
sreten
The real question is related to incorporating bass boost in the
feedback loop of power amplifiers by using a high pass filter.
As gain at high frequencies will not change I can't see any
issues with compensation or lack of gain bandwidth product.
:)/sreten.
pinkmouse
I haven't tried it recently, but Analog have a filter design tool that I believe will allow gain.
sreten
quote:
yes there is a field for gain but the tool doesn't seem to work.
(or setting the gain to 30 breaks the tool !)
:)/sreten.
ilimzn
Yes, in fact it is quite easy to do.
Think of a regular MFB filter with amplifer block with gain = 1. You have a feedback path from output to the input network in form of a capacitor. In order to provide 30dB gain, you need to move the feedback pick-off point from the output of the amp (Av=1) to a point where Av=1 regardless of amp gain, and this in fact will be the junction of the resistor network that sets the 30dB gain, i.e. the inverting input of the 'OPamp'. In order for this to work with reasonable accuracy, the feedback network needs to be low impedance, or at least the impedance as seen from the non-inverting OPamp input should be much lower than that of the filter network at the input of the amp. This is the less of a problem, the higher the gain required, and the better the drive capability of the OPamp.
For instance, assuming a NE5532 OPamp, and assuming twice the minimum load is used, the same load can be presented in the form of the feedback network. Example: if you use 600ohms as the minimum total load for the 5532, and 1.2k load of the next stage, then your feedback network must have 1.2k end-to end. For a gain of 30dB = 31.62, you come up with 1162 ohms from output to inverting input, and 38 ohms from inverting input to ground. The impedance seen at the non-inverting input is roughly equal 38 ohms, so this is perfectly acceptable for all normal values of your filter components. The remaining problem is DC offset, whch can be catered for in a number of ways, but this is outside of the scope of this topic.
I've been using this trick for, amongst other things, making simple two-way active speakers on the cheap, you use a chip power amp instead of the OPamp. Since the chip amp normally requires at least 24dB of gain to insure stability, and by definition drives low impedances, it is quite easy to use in this manner.
djk
Just pretend the feedback node of the power amp is the output node of a unity gain opamp. If the lower arm feedback resistor is low enough then you won't have any problems.
If the lower arm feedback resistor is a high value, then just add a voltage divider at the output of the amp that has the same ratio as the feedback resistor pair. Sony did this around a 30dB preamp line stage, works fine.
The NAD 3020 integrated amp uses this on the main power amp input too, the lower arm feedback resistor is 27R.
infinia
If you think you need 30db of bass boost something is really wrong.
example: Running your mids and HF driver with 10 Watts
about 100 dB SPL. The power amp and woofer would be running 30 db higher or 10,000 Watts to get the low freq extention.
Not too realistic
AndrewT
I think he said 30db of gain, not bass boost.
infinia
Post #4&6 he is looking at Linkwitz Transform circuit in an active eq. So bass boost is correct.
theChris
why not just use a lowpass filter with a gain? i'm not sure i see what benefit you get with a highpass function in a feedback network.
in general, there is a balence between component values and gain. for a sallen key filter, i have the analysis done in generic terms, R, C, k, Fc, Q for a few cases. for equal value components, you can't get a gain of 4, but for unequal components you can choose almost anything. but note that in a sallen-key the component variations will cause the filter to be further from the design on paper!
3 opamp designs can often have better tolerances, but are a bit excessive.
for learning, look for nuhertz filter free (or pro or lite). these programs are excessively expensive, made more for real engineering firms over the casual user. the pro version is an excellent trial and error learning tool. you can see a passive version of a design, move it to an active implentation, or make a digital implementation. view component tolerences, ect... filter free lets you make up to 3rd order filters, making it a great tool.
sreten
Low pass ? at bass frequencies ?
What I was wondering was if you wanted to build a speaker with
overdamped bass and then add some bass boost and very low
frequency rejection, i.e. a 2nd order highpass with Q=2 would
give 6dB boost and low frequency rejection, could this be built
into the power amplifiers feedback network avoiding an op-amp.
Seems that you can do this, and it is a very useful technique.
:)/sreten.
theChris
ok, now i understand. I'd get a copy of filter free, and look into the various topologies. i think you want a chebychev filter from what it sounds. they have postive and negative single amplifer biquads generators.
consort_ee_um
Sreten's idea for the speaker is a good one. Don Keele wrote about in in 1975 see:
http://www.dbkeele.com/papers.htm
Scroll down to paper no 8.
The filter can simply be an underdamped Sallen and Key type see the data sheet for the TDA2030A for implenting these types of filter in active speakers
http://us.st.com/stonline/books/ascii/docs/1459.htm
jcx
active filters often require fixed drive impedance (usually assumed to be ~=0 )
not a great idea for a general purpose amp which may see anything from near 0 to over 1 K source Z from even desktop cd players - depending on manufacturer
throw in boutique tube preamps, transformer or resistor stepped attenuator/passive preamps and the input may go beyond 5 K and may vary with volume setting
ps: avoid Sallen-Key positive feedback filters at high gains - for typical power amplifier gains Q sensitivity is impractically high, trimming required even with 1 % components (and when did you last try to buy a 1% cap?)
AndrewT
I think that's why MFB is suggested for higher Q filters.
Less sensitive to errors.
sreten
from what I understand you take a unity gain sallen and key filter,
but instead of taking the feedback from the output (which is the
same as the - input) you add the gain setting resistors of the
power amplifier and take the filter feedback from the - input.
As it a moderate Q 2nd order filter (Q = 2 to 3 typically) it could
be regarded as a high ripple Chebyshev, but not really the point.
You would need to ensure you don't compromise the input
impedance, i.e. make the filter sensitive to source impedance.
:)/sreten.
infinia
Not sure what you are trying to accomplish exactly?
Here is a link for some speaker EQ stuff at line level with out op-amps?
http://www.linkwitzlab.com/proto.htm
Hope it helps.
theChris
he is looking to combine the following:
1.) bass boost, boost audible bass.
2.) subsonic (aka rumble) filter, attenuate inaudible bass in hopes to reduce excursion.
3.) amplification.
all into a single design. a high Q highpass filter with gain will give a boost to some bass frequencies while rejecting lower bass frequencies and the gain allows for the amplification.
If you don't need a _good_ 2nd order function, you should be able to accomplish the other two goals easily. you could get away with a highpass on the input, followed by a highpass on the inv to gnd network, and a resistor in parallel with a (resistor - capacitor series). should be able to get a Q = 0.5 highpass, and a variable bass boost.
other variations to concider might be placing a LOW QUALITY twin-t network in the feedback, or on the input. these should be fairly component tolerant.
there are many possibilites that acheive the 3 goals stated thus far. the MFB thing might work as well.
consort_ee_um
Here is a circuit which conforms to the above It gives 6db of boost on a gain of 27dB. The ratio of R1 and R2 defines the amount of boost. Can use any power op-amp with the proviso that the input resistance is high. ST quote 5Mohms for the TDA2030A. The naughty people at National do not quote an input resistance for the LM3866 but they do say in the notes that a 100k resistor across the input defines the input resistance as 100K thus implying the resistance is high enough not to affect the filter.
This circuit in combination with an underdamped vented box design would make a better sub-woofer IMHO than the popular closed box and Linkwitz transform design. It will have lower cone excursion and voice coil temperature for the same acoustic power.
djk
Nice to see a drawing of what I said in post #8
Post #8
Page generated in 0.052372932434082 seconds with 17 queries,
spending 0.00709081 doing MySQL queries and 0.04528213 doing PHP things.
