diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Is this "el cheapo" Velleman100wRMS kit good enough for a subwoofer amp? - Click HERE for Original Thread
Spasticteapot
While searching through an electonics kit store, I found quite a deal on a simple solid-state amplifier. It's probbably not amazing, but would it be good enough to use as a subwoofer amplifier? Most plate-amps are much more expensive, but the actual parts cost for a "sonotube" subwoofer is not much at all, and this might be a nice way to make a cheap woofer.
sreten
The basic velleman amplifier is good enough for a subwoofer.
I'd upgrade the value of the smoothing capacitors though.
:)/sreten.
Spasticteapot
Out of curiousity, what is the reason that I've yet to see anyone else using one?
Taligent
Hi Spasticteapot,
Depends on the price of the kit - MCM currently has a 150w RMS @ 4 ohm plate amp available for $49.95, which is hard to beat on price and convenience.
-Nikhil
Spasticteapot
Here's the kit I found:
http://www.electronics123.com/s.nl/...C323/id.1900/.f
sreten
Given the choice, I'd go the $50 plate amp route every time.
:)/sreten.
Page generated in 0.019201040267944 seconds with 17 queries,
spending 0.00643873 doing MySQL queries and 0.01276231 doing PHP things.
Please support our sponsor.
