diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
luxmAN M-117 power realys SHOT! HELP! - Click HERE for Original Thread
analogue_lover
HI Gang!
I just was given a Luxman M-117, but both power relays are shot. What specifically would work in place????
THANKS!
Mike:)
anatech
Hi Mike,
Are you talking about the two relays on the speaker terminal PCB? They would be RL401/402, P/N 80T92285F01 (JC2AF).
So, what's wrong with them? If the contacts are intermittent, but not burned, they can be cleaned.
-Chris
kensetsu
Are we referring to the speaker protection circuitry?
Thanks, Nick
anatech
Hi Nick,
Hah! Found the thread you were referring to.
The answer is - 42.
Yup, the speaker protection relays are commonly defective. The contacts either become oxidized and burnt, or arced to death. Do not burnish the contacts. The plating is too thin for that treatment.
-Chris
kensetsu
Hi Chris,
Thanks for the fast response. With respect to repairs on the Luxman M-117 Speaker protection, if the contacts are burned out are the parts still available?
Thanks, Nick
anatech
Hi Nick,
Those relays are normally available through standard parts jobbers. Check Newark, Digi-Key and the other usual suspects.
-Chris
Page generated in 0.019218921661377 seconds with 16 queries,
spending 0.00774360 doing MySQL queries and 0.01147532 doing PHP things.
Please support our sponsor.
