diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
oscilloscope at victoria st. vinnie's. twelve bux, cheap! - Click HERE for Original Thread
maxro
There is a Starkit oscilloscope at the local St. Vincent de Paul for $12 if anyone's interested. Actually there were two, but I bought the Heathkit one. Any ideas on how to use it?
Max
tade
Is it in workign order? I think I might like to own one!
maxro
I think it sort of works. I really don't know anything about these things. It powers on, but emits a quiet humming noise. With nothing hooked up to it, there is a trace that looks like a partial waveform. I would think that it should be a stationary point with no input. I fiddled with the dials but couldn't get the trace to stand still. Probably not worth shipping as it's rather big and heavy.
I took the Heathkit one because it has a stationary trace and maximum frequency of 150kHz, rather than the Starkit's 75kHz. Also it doesn't hum.
Max
tade
i see. I dont think i am could manage to fix it even if it werent bulky. Good score though.
tomtt
first scope i bought, cleaned the pots, first thing, with wd-40.
showed the guy i bought it from, he says, i couldn't get that fine
of a trace-
also a heath kit
lgreen
Max
You may be seeing AC noise, change the "time/div" control and the trace should move faster, you should not get a dot. Hook it up to a test tone (you can download some from my web site below) and see if you can see the wave. You want to go at like 2 or 5v/div (vertical) and vary the horiz (time div), AC couple.
You read these per division on the screen so at 1v/div (vertical) a trace that goes up 1 div = 1volt. time/div is on horiz, note that frequency = 1/time to compute what freq you are seeing.
have fun, you can figure it out.
maxro
Well, actually that was on the humming one that I didn't get. Probably the ac hum I was hearing that was showing up on the screen.
I was just playing with mine and getting a nice horizontal line, but it started to smell bad (no magic smoke, though), so I turned it off and unplugged it. I'll investigate further, later on. Hope I didn't pick the wrong one.
Max
Page generated in 0.029017925262451 seconds with 17 queries,
spending 0.00912309 doing MySQL queries and 0.01989484 doing PHP things.
