diyAudio.com diyAudio Forums Archive > Top > Source > Digital
AL1201G based DAC - looking for input - Click HERE for Original Thread
Russ White
I am designing a balanced output AL1201G based DAC from wavefront.
The DAC will take S/PDIF in, and uses the CS8414 receiver. The output is provided by 4 single opamps, and there is an auto reset function provided by a TLC7705 and SN74HC04. When there is no signal lock the voltage supervisor resets the receiver repeatedly until the signal is locked.
The digial and analog GND planes are seperate and there is a leaded ferrite bead between them.
Does it look sane? This is my very first attempt at a DAC so any advice is welcome.
I am especially looking for input around the CS8414 and the AL1201G.
Russ White
The board may end up looking something like this (it is an early layout subject to change)
hayenc
I would be curious to know reasons for selecting the AL1201G over other choices, such as the Wolfson 8740. I could not find much in any threads other than the Burr Brown chips.
Russ White
quote:
I am not familiar with that part, but my part choices here are based partly on input from a couple "recording biz" engineers I know here in Nashville who really like the AL1201. Also I chose it because it is SOIC which is as small as I want to go, no SSOP for me. (well not yet anyway) :)
The AL1201 is also very easy to use. And since this is my first run at a DAC I want something extremely hard to muck up. :D
Cheers!
Russ
hayenc
I have the eval kit for the 8740, plus a Benchmark DAC1 and Peter's nos 1543 DAC's, so I look forward to this project and doing some comparisons.
metalman
Ah! Russ! You are beating to me to the punch on producing a balanced output DAC, a project I have been slowly tinkering with for some time without getting far enough to have anything worth posting. Your approach looks very appealing, I was getting led astray by overthinking and overdesigning the power feeds and clocking arrangements.
Last question: When do you find time to sleep?
Cheers, Terry
b-square
are you planning to include the obligatory high performance clock input?
Russ White
I don't feel obliged to. :)
ble0t
Only advice I would have is to change some of the routing (it's obvious from even the EAGLE3D pic). The FILT pin is very sensitive and should have very short traces to the filter caps/resistors (i.e. use SMD parts in this case). Also, the corresponding VA+ and AGND pins should also have decoupling as close as possible i.e. use SMD if possible.
Russ White
Wow, so I guess I didn't screw it up too bad? I am honestly surprised as this was my first shot at it. I will try changing the caps as you suggest.
Cheers!
Russ
lgreen
Hmmm.... since you think ahead, can you think of presizing the board to slide into a small case?
Like Parts Express "heat sink box"
Russ White
Hmm thats a nice little case, what width would it take to get it to slide in? It seems from the manufacturers site that the ouside width is 3.54" So would it be like 3.4" PCB width? Hard for me tell... Anyone know?
b-square
3.4" seems right (assuming the narrowest part of the wall is 1/16"), but i can't find any measurements on either the parts express or penn fabrication sites. if parts express can't provide that information on the phone or in email, someone may have to sacrifice $8 to discover the truth.
hayenc
Might also consider the Hammond 1455 (D-K and Mouser both carry) series case. One concern is having room for two XLR's and the coax/phono for digital. Might be tight on the PE box.
lgreen
quote:
Sorry, thought there was a data sheet. I have one and will measure it in the next few days. I did a project for it, cut a perfboard to fit, epoxied the edges and filed and sanded the epoxy to make it smooth, it would have been good to know the inner dimensions first.
If you check my project link you will see that it is no problem to fit 2 XLRs and a coax/phono. I successfully fit a ton of connectors on this box, including WBT phono's which are larger than the typical connector.
The only disadvantages of this box are - (a) the end plates are steel so its harder to drill them, (b) the aluminum box needs to be tapped and threaded for screws to hold the end plates (c) the box top/bottom does not come apart, you need to slide the board in, but you knew that.
I think the box looks great by the way.
Don't ask me why the end plates are steel and the box is aluminum, but they do match up.
joster
Will the power supply fit in there as well? Or will that be external?
Russ White
quote:
I actually think I can make it fit for the 8" case.
lgreen
OK, time to test your vernier skills.
This is a pic measuring the board inside the box. By my read the board is 8.498 cm wide. It fits with some room to spare. Board width measurement
Here is an inside measurement of the box itself. By my read its 8.505 cm wide, but I've got a better view of the original calipers than is shown in the pic.
Box Inner dimension measurement.
How is the design coming?
Russ White
Thanks for the data! :)
The design is comi g along very well. I am just switching some parts around (mostly making passives SMTs).
Also using a dual NOT gate instead of what I had as I only need two.
But all in all the circuit is nearly complete. I ordered some of the DAC chips last week. They should be here tomorrow.
I am hoping to get some prototype PCBs made in the next couple weeks.
Also I am making some decissions about the power suppy, and th use of PCB mounted trafo. I think I will use use two PCBs both designed to mount flush at both ends of the box.
Also I am looking at other similar eclosures just to see what will be the best/easiest chasis to use.
The DAC PCB will be designed for both optical S/PDIF(TORX) as well as standard S/PDIF.
Cheers!
Russ
ezkcdude
Any updates on this project?
b-square
it would be great if this board had an option for i2s input instead of just spdif.
thanks,
bb
Russ White
Just that I am atively working on it still. I will post some more details very soon. I have actually decided to go very "modular" with this design with a seperate PCB for output filtering/buffering if desired.
Glad someone other than just me is still interested. :)
ezkcdude
Thanks, Russ. I'm in the (very) early planning stages of designing my first DAC, hence, the interest.
Russ White
quote:
thanks,
bb
I would be glad to include I2S but I am not sure if the AL1201G can accept I2S or if I would have to convert it.
Russ White
I asked WaveFront about making the AL1201 accept I2C and here is the response I got:
quote:
Hi Russ,
The AL1201G cannot directly accept I2S input, as it is exepcting left justified input. However, since I2S is just left justified data shifted to the right by 1 bit, you can undo the shift by shifting the wordclock to the right by 1 bit.
By feeding a DFF's data input with wordclock, and the clock input with bitclock (64xFs) whose rising edge is aligned with the edges of wordclock, the output will be a properly shifted wordclock that can be fed to the AL1201G without having to do anything to the audio datastream. You can do this with something like a 74HC74.
Now please understand I am no digital expert in the least, and a few of those terms in there have me scratching my head. I would be so grateful if someone could show me a diagram or schematic of how this might work. Or even just point me to a good place where I could go read about it.
Cheers!
Russ
chris719
Hmm, that may work, but you also are inverting left and right channels since I2S uses word clock low for left and not right channel data, not really a big problem.
b-square
here's a vote for using a different dac. lack of i2s input and lack of support for sampling rates above 55kHz are pretty weak.
bb
rfbrw
bb
Consider it an impetus to start your own design.
Russ White
bb
I am going forward with this DAC for several reasons.
1) I have heard a professional example of a DAC using this chip and it sounds very good.
2) I love that it needs no I/V stage.
3) Balanced output.
4) Monolithlic design which requires no external clock or PLL.
5) Very good dynamic range.
6) Convenient easy to DIY solder SOIC package.
7) Easy to obtain and at a low cost (about $4.50).
I2S input was never a huge priority for me, but I still think it would be very possible to add it. In fact one could easily make a stakable PCB which used something like a PCM2707 and a DFF or two to get what we need for I2S into the AL1201.
Do you know a balanced output SOIC or DIP standalone DAC chip? I don't want to do anything smaller then SOIC and I don't want a uC on the PCB nor an oscillator. I would be very happy to consider it if you do.
For now I am quite happy with 48KHz as I plan on just using this with CD transport or soundcard SPDIF out.
This is not the only DAC I plan to design, just the first. So I will keep it simple (yet modular) , and relatively cheap.
Cheers!
Russ
b-square
quote:
i thought we were just supposed to sit around waiting for people to design stuff and then get all excited and say we wanted in on the group buy!
bb
rfbrw
bb
Especially when it annoys Ulas.
Jocko Homo
Wow........2 posts in row that I agree with. When was the last time that happened?
Back to lurking. Remember.......I may be away, but never far enough away that I can't keep my eyes on the troublemakers.
Just what you needed: one more reason to be paranoid. Just because you imagine that someone is out to get you does not mean that they really aren't.
Jocko
ezkcdude
I for one would love if there was a sticky thread where people put their finished and working designs. It would be a great resource for newbs like myself who keep resurrecting old threads in search of ideas.
Russ White
I have shelved this design in favor of a new one which can be found here:
http://www.diyaudio.com/forums/show...4368#post914368
Page generated in 0.073548078536987 seconds with 17 queries,
spending 0.01034236 doing MySQL queries and 0.06320572 doing PHP things.
