diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Lazy transistor? - Click HERE for Original Thread
gfinlayson
Here's one for you SS experts.
I have two monobloc power amps which are essentially Naim NAP 135 clones. One of them has developed an intermittent problem. Music is severely distorted, as in half the output isn't working sort of distortion.
Anyway, I got the lid off and checked it out. When powered up, with no signal applied, I should see about 4.4 mV (20 mA bias) across R29 and R30 (schematic below). I'm getting 2 odd mV across R29, but nothing across R30, and no base-emitter or base-collector drop across Q10, the MJE15033 driver tranny. Eventually, if left powered up on the bench for a while, Q10 springs into life and the bias on both sides settles out around 20 mA (4.4 mV give or take across R29 and R30). Once it's up and running, it sounds just fine.
The problem doesn't occur all of the time. It'll power up just fine about 5 or 6 times, and the next time it'll play up. I've checked everything I can think of, replaced all of the signal transistors as I had plenty of spares (all the ones I took out tested fine), replaced the diodes, and Q12. The only tranny I haven't replaced is Q10 as I currently don't have a spare. I took out Q10 and tested it with the diode tester on my multimeter and the base-emitter and base-collector drops were OK ~ 0.5 to 0.6 V.
Is Q10 likely to be at fault? I've never experienced intermittent operation on transistors. I thought they usually work or they don't. Can anyone offer any suggestions?
pinkmouse
Hmm. Blanket resolder and swap out C8 would be my first move.
gfinlayson
Leaky cap? Never thought of that. I've got a spare 47uF 63V I can try. If it works, then I'll order up a replacement Black Gate :bawling:
gfinlayson
Ok, it's not C8. I swapped it out, and on first power up, there was no output from the MJE15033. I tested the Black Gate on my LCR meter, and it was reading 44.3 uF, which is well within the tolerance spec, so back in it goes. :scratch:
gfinlayson
This is weird. The base-emitter voltage on Q10 jumps around all over the place after power up - pretty much everywhere from 100 mV to 400 mV. Eventually, it pulls its way up to over 500 mV, and the tranny kicks in. Once it's in it stays in and the voltage across R30 settles at just over 4 mV.:scratch:
EC8010
OK, you have a problem around Q10. I suppose it's just possible that the transistor is intermittent. I've never seen that fault before, but then, I'd never seen a transistor go noisy before fixing the amplifier in my valve tester. My money would be on soldered joints or cracked tracks. You've very nearly nailed the problem. If Q10 isn't switching on, then it's either not being told to switch on, or it doesn't have any power to switch on. Rather than just checking Vbe, measure all the absolute voltages on the transistor pins. If it's a solder joint, it's essential to wick away the contaminated solder and clean the surfaces before applying fresh solder.
gfinlayson
Pinkmouse,
Are you still up for an audition of the new speakers - if I can get this amp working properly (otherwise it'll be left hand only mono)?
Graeme
pinkmouse
Sure, might be a week or so though, I'm tied up with family stuff at the moment.
pinkmouse
quote:
I'm with EC8010, it sounds more and more like a PCB issue, possibly settling down as something heats up. Have you tried turning the amp off and checking tracks for continuity with a meter?
cliff
I've had intermittent wire-bond failures on transistors before now.
Usually findable with freezer spray. Have you tried that?
EC8010
Yes, good point (and welcome to the forum). Freezer spray is very effective (although wildly environmentally unsound). Another good tool is a hair dryer. I got a very odd look from the girlie in the chemists when I bought a hair dryer. She didn't actually say, "Why do you need a hair dryer?" but I could see what was on her mind. Thumping things with a screwdriver handle sometimes pinpoints the fault.
gfinlayson
Funny, I've had similar looks in chemists before, when someone asks "Can I help you?", and I reply "Yes, I'm looking for some hair gel".
Anyway, back to the point. It seems I may have found the problem. I've been all over the board checking in-track continuity and track to track insulation. There was a tiny little nib of solder between two tracks on the board, essentially between the collector of Q5 and the output. It measured about 60 kohm between tracks with the meter. After a quick touch with a soldering iron, it went up to about 9 Mohm. Am I right in thinking that this would be leaking current away, stopping C8 from charging, and thus depriving Q10 of base current?
Every switch on since, the voltage across R30 has popped straight up to 4.4 mV.
Thanks everyone for the suggestions.
I can now go and work that flat spot out of my forehead :headbash:
Graeme
EC8010
Sounds like you're in business.
pinkmouse
Excellent! Just shows how easy it is to fix things if you proceed in a methodical way.
gfinlayson
I suppose C8 was 'leaky' after all.......
Well spotted Pinkmouse.
EC8010
quote:
Absolutely. No need to tear your hair out.
pinkmouse
Not really, if nothing's burnt, and the transistors are fine, electros with their relatively short lifespan are the best place to look. ;)
-_nando-_
3281 ??
Fake transistor?! :devilr:
gfinlayson
I doubt very much the 3281As are fake. They are On-Semi brand and were sourced from Farnell by a friend of mine who is an electronic components distributor in the UK.
Edit:
I also doubt very much that fake 3281s could sound this good.
-_nando-_
Oh ! If it's from farnell, sure they are genuine parts...
I saw one time in my hole life a problem like you are describing with genuine parts ! This is why I suspected about a fake one... Are you sure that ALL parts (ie. driver transistors) are genuines?
Once, I had problems with an RF transmitter, there was no fake parts, but the transistor refused to oscilate! :clown: Then I replaced with a new one (from the same seller) and it worked perfect. Genuine parts can have problems too !
gfinlayson
Nando,
I'm pretty sure all of the parts are genuine. 90% of the parts came from Farnell. All the driver and output trannies came from there. All are Onsemi, which Farnell buy direct from Onsemi, so no fakes. Some of the signal transistors came from Nikko electronics as they are hard to find, e.g. 2SC2547E. There's so little demand for them that they're not even worth faking.
I am aware that there are a lot of fake semiconductors out there, which is why I only buy from reputable suppliers, or from my friend who is a distributor and has been in the business a long time. She supplies most of her stuff to small companies who make very specialist calibration and test equipment etc. It's not worth buying bargain components, as what you get may not be what you want.
Anyay the problem turned out to be a semi-short between two tracks on the PCB, which was causng a very slow start up to the bias transistor. It's fine now.
Graeme
cliff
quote:
Nah! Hairdryers are for wimps! ;)
Get thee a 2Kw industral air gun: It can reduce fibreglass pcb to a smoldering charrred mess in seconds. :xeye:
Cal Weldon
quote:
Nah, hair dryers are for people with hair.
Page generated in 0.061378002166748 seconds with 17 queries,
spending 0.01620650 doing MySQL queries and 0.04517150 doing PHP things.
Please support our sponsor.
