diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Relationship between master clocks, system clocks, and audio freqs - Click HERE for Original Thread
Garbz
This is something I can't quite understand. Digital sources have a master clock in them usually in the form of a crystal oscillator. In my cdplayer's case this is 27Mhz.
What is the relationship between this clock and the system clock of a DAC (i.e. the MCLK line in an I2S signal) which is not 27MHz IIRC. While on these relationships at what frequency is S/PDIF clocked?
And how does this mess relate to the frequency of the digital audio (44.1khz 48khz 96khz etc)
A 8
Your cdp can not be 27Mhz as it has a 44.1khz base only. A dvd player has a 27Mhz clock to handle the video processing.
The pic shows typical relationship between bit, word and data.
A 8
Clock vs sampling freq
Garbz
Ok so can you tell me how the clock is derrived from the 27Mhz crystal oscillator that I replaced with a 27mhz Tentclock? (indeed it is a dvd-audio player). But the tentclock also re-clocks the S/PDIF output through a flipflop no doubt. How would that work since the result is 27Mhz.
A 8
Nippon
It also explains why reclocking works
Elso Kwak
quote:
Originally posted by A 8
Nippon
In my humble opinion synchronous reclocking does not bring a thing
:bigeyes:
A 8
You must mean other then getting all samples exactly right:D
Elso Kwak
I just tried it!
:rolleyes:
Garbz
IMHO asynchronous reclocking doesn't work.
Synchronous reclocking however I found (did this to the output of my cdplayer) yielded a slight bit of improvment. That said my standard source was a shocker to begin with :dodgy:
Garbz
Hey A8 thanks for that link it obviously explains that a cdplayer can derrive it's audio/video clocks from a 27Mhz crystal.
But i'm still at a loss as to how S/PDIF then propegates at 27Mhz if that is not an audio frequency. I could be way off the mark but it appears that the S/PDIF output of a Tentlabs XO-3 reclocker runs at the frequency of the crystal itself.
A 8
The 27mhz is not free flowing or fully asynchronous to the audio stream, all the audio streams are a direct decendent of the 27mhz master clock.
There is always a fixed timing difference and its not big enough to miss samples.
Page generated in 0.028361082077026 seconds with 17 queries,
spending 0.00790930 doing MySQL queries and 0.02045178 doing PHP things.
Please support our sponsor.
