diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
iteration limit reached: another numb noob Q - Click HERE for Original Thread
Onvinyl
when simulating my circuit in ltspice it works ok with 'universal opamp' model. if I use a certain model, be it from LT or a third party, I get an error saying: 'iteration limit reached'. The circuit works in reality.
Why is that, and how to cope?
Rüdiger
lineup
maybe you should build the thing ....
then is REALLY working audio circuit
:cool: :( :cool: :( :cool:
Onvinyl
He lineup,
what a worthwhile advice :cannotbe:
It *is* build in reality, and not working in sim (anyway, better than the other way round). I did so to check what happens to happen both in sim and reality if I change something.
The sim works now, I replaced *all* opamps with their dedicated models. It seems you can't mix both universal and specific models, of course, I don't know if this is true in all cases.
Rüdiger
Edit: Wrong! It seems to work only randomly. If I change anything (e.g. add a parallel cap to Rf), then I get the error warning again
Geek
That's a common Spice engine error and opamp simulations are the worst offenders. Can mean a myriad of things from too complex of a circuit or signal to not enough info to make the calculations.
I've found that sometimes the silliest things can cure it - like varying a resistor by one ohm (99.999K instead of 100K on a feedback resistor for example) and other times it plain won't run.
Can you try another, more co-operative opamp model with similar charcteristics (like a TL072 for an 082)? The real-life difference won't be significant.
Cheers!
Page generated in 0.031255006790161 seconds with 16 queries,
spending 0.00832438 doing MySQL queries and 0.02293062 doing PHP things.
