diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
Weird (?) problem with 317 regulator - Click HERE for Original Thread
Onvinyl
I have some simple lm317 regulator circuits, like in the datasheets with added Cadj. While playing around with a more or less antique scope I saw that one circuit does not correct low frequency shifts between say 0.5 - 4 Hz (A 'jumping' y-axis). This with input at x10, 0.02V/div at diverse time/div settings. It is also a bit noisier. The other boards correct the shifting before the regs. Pluggin in a new 317 changed nothing, and I can't find a defective part. What is it, and what shall I look for?
Rüdiger
Onvinyl
... the input cap is about 1,5 inches away, placing an additional 0.1uF Cap close to the pin solved it.
Rüdiger
Page generated in 0.015661001205444 seconds with 16 queries,
spending 0.00771189 doing MySQL queries and 0.00794911 doing PHP things.
