diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Is a bridge / parallel configuration of 3875 is better for my speaker ? - Click HERE for Original Thread
100db
Hello,
I'm using inverted LM 3875 with 24-0-24 v power supply ( +/- 35v to the pin).
I would like to know if I use bridge or bridge+parallel configuration can make my gain clone drive my speaker better ?
My speaker is Scan 15w-8530 + Vifa XT25, serie XO.
Bazukaz
I depends on your loadspeaker's impedance.
35V is quite much for this amp.For this voltage , a bridged config will hardly be usable for any lower loadspeaker impedances than 16Ohms.
You should search for overture design guide excel spreadsheet at www.national.com to get an idea what output powers at known impedance speakers you should expect.
Lukas.
100db
Bridge will make the GC see a speaker as half impedance and parallel will push it back to normal impedance, am I understand correct ?
sreten
quote:
Correct. But how about 3 paralleled bridged pairs ?
:)/sreten.
100db
To make it handle a lower impedance speaker properly ?
This would be very interesting, anybody try this before ?
:D
Khron
Yes, it's been tried before, except it's with 6 LM3886s...
http://www.shine7.com/audio/bpa300.htm
DIYdo
From my BPO experiences you don't get the power gains expected. For the extra work load I have found it easier and more practical to use discreet components. Not saying not to try though. Chips are very easy to work with, and are very reliable.
sreten
Hmm...
Its not 3 paralleled bridged pairs, its a pair of 3 paralleled amplifiers bridged.
:)/sreten.
Page generated in 0.026247978210449 seconds with 17 queries,
spending 0.00845361 doing MySQL queries and 0.01779437 doing PHP things.
Please support our sponsor.
