diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Balance LM3886 not working - Click HERE for Original Thread
Ipanema
Guys,
I have made this balance LM3886 as the schematic attached. The problem is both positve and negative output voltage goes to near VDD upon power ON. Found this schematic from instrumentation amplifier circuit.
What possibly went wrong with this circuit? Pls help.
Thanks. :)
DcibeL
Your schematic doesn't have VDD on it. You have used a non-polarized cap for C1?
Some pictures of your project would be helpful, to check the wiring, make sure all the caps are in the right way, no solder bridges, etc.
Ipanema
Hi Dcibel,
Sorry, the the positive supply is labelled as VCC instead of VDD while the negative suupply is VEE.
C1 (zobel) is Wima MKS2 non-polar.
I 've attached the layout. The red line is my jumper wire. Do you see anything wrong with the layout as well? I'll take picture of the board and post here tomorrow.
Thanks. :)
Ipanema
Layout
DcibeL
My thought is that the small track from pin 1 to pin 5 (VCC) that goes over pin 3 (output) is shorting to pin 3. Can you check this with a multimeter? Also check on your board that the track on pin 8 does not short to pin 9 or 10.
Ipanema
Hi Dcibel,
I have check through the board and nothing is shorting. Could it be that the the feedback resistor R10 is not physically grounded?
Anyone have tried this circuit before?
Thanks.
DcibeL
As far as I can tell the circuit should work. When one input is posotive, and the other is negative (balanced input), then the feedback of one chip will be opposite of the feedback of the other, so...I don't know it's hard to explain but it should work. You could test that the circuit works by doing a Spice simulation using a couple of op-amps. That is, provided your circuit design software does Spice simulations.
Normally for a balanced input, you would just apply one signal to the posotive input, and one to the negative. But I guess this way you get a larger output like a bridge configuration.
Page generated in 0.027122020721436 seconds with 16 queries,
spending 0.01009107 doing MySQL queries and 0.01703095 doing PHP things.
Please support our sponsor.
