diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Lighting and OHP
High Temperature Wire For OHP Lamp? - Click HERE for Original Thread
Gadgethead
Hello folks!
I've been test runnning my projector with nice results even though it's light engine is only a 410 watt OHP lamp with custom holder I made myself (do plan on upgrading to halide later). The wires that I use to hook it up are high temperature wiring from the hardware store (braided wired, silicone insulator, fiberglass sleeve).
My wife has been having the problem of weh everytime I fire up the PJ for a while her nose begins to burn to what she describes as a chemical type fume. I cannot smell a certain fume but even my nose does hurt a little after running the machine as well.
This morning I decided to investigate a few hunches and leanred that the type of wire that I'm using is rated to only about 250 degreen Celcius. I know that anything made of wood or paper near the lamp will catch on fire so I can guess that the temperature of the bulb is getting around 600 degreen farenheit!
I do have a cooling fan blowing on the bulb and it works well, the bulb never breaks and the holder I made is actually cool enough to touch, it's just the wires in the back get so blasted hot that I think that the silicon insulator is fuming and causing my wife her nasal discomfort.
Are any of you familiar with Mica/glass wire? or know as furnace wire? It's rated to about 850 farenheit and that may be what I have to look for now. If that doesn't work I may even try to cast my own wire insulators with Water Putty (plaster).
Thanx in advance!
Chris B. in Iowa
Page generated in 0.16592407226562 seconds with 16 queries,
spending 0.12508464 doing MySQL queries and 0.04083943 doing PHP things.
