diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Why separate AC heater supplies for driver and power tubes? - Click HERE for Original Thread
leadbelly
I have seen it mentioned in threads about the benefit of using a separate transformer winding for the driver tubes than the power tubes of an amp rather than the same secondary. I mean of course specifically about instances where a single one will do and not designs where heater-cathode voltage is the issue. What's the basis of this improvement? Is it poor noise separation between heater and the anode/cathode? Is is that lower AC currents in the wire reduce EMF? I am trying to decide if it is worth the bother in my amp, the draw for the heaters of the driver tubes is 1.2A and the draw for the power tubes is 3.0A.
arnoldc
I don't know what kind of tubes you're using on your amp (DHT, IDHT) but for DHT tubes like the 2A3 when using cathode bias, I believe separate windings are required.
Having said that, I also built an EL34 amp and shared the same 6.3V heater winding with the drivers (no heater elevation) and I did not have any problems, or so I think.
I'm also interested in the logic behind it.
leadbelly
Oops, sorry, I meant indirectly heated. I can see that there are other issues for DHT.
lndm
Heater windings carry high current. This means inductive radiation can be significant where windings are near stages with low level signals. Hum is the problem. Mainly with phono preamps. You can twist the windings, and you can connect them with separate cable runs from the source. This way you avoid a string of heaters running from the same cable which then carries a high current.
Page generated in 0.019500017166138 seconds with 16 queries,
spending 0.00830817 doing MySQL queries and 0.01119184 doing PHP things.
Please support our sponsor.
