diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Shunt regulator - Click HERE for Original Thread
tubee
I have a trouble with my solid-state regulated diy Pre-amp: its motorboating in the Phono-stage. (Because the current draw from tubes is around the minimum of the regulator TL783, +/- 14 mA)
Have a box full of tubes, and therefore i was thinking of a EL84 combined with a gas-reference (85A1) to swap the solid state for a shunt regulator.
Has anyone experience with this? Thanks.
Geek
Shunt regulators are great, but have higher impedance than series in my experiments.
How much voltage you need? Here's a SS one I designed specifically for motorboating-tendency preamps (12AT7's are horrible for that).
I have a good tube design too somewhere I can dig out.
tubee
Hello Geek, thanks for reply so quick.
Yes the shunt should work great to me too for my pre. Your SS could improve it allready.
In is +/- 270V , want about 210V out.
The line stage is SRPP 6N1P (great tube, but large heater current)
The phono stage is 2 times CCS 12AX7 with passive RIAA inbetween.
I have just got a allmost new Benz Gold MC to play with so now i want to resolve motorboating troubles. The MM had higher output and i could just manage to keep below the motorboating level.
If you can find the schematic it would be great, but i don't have a hurry with it. Have been looking on the net but shunt is not used often as series PS.
Geek
Hi Tubee,
Funny you mention that tube lineup - one of the projects I'm using the SS reg in now is a preamp with a 6N2P phono and 6N1P in a L-W CF line driver :D
Here's my tube reg (based on the one by Steve Bench). No shunt ones on "paper" though.
choky
two OC3 in series for 210 V
nothing fancier
and-ye,bunch of Ls in LC filter stages,if you can......
edit:
you can always add shunt resistor in parallel to load,if you use series reg as 783
tubee
Choky: thought of a shunt R as load on TL 783 also, but sound will improve too with an tubed regulator,a nice goal.
Big or a lot of L's are not an option, no space in cabinet. But will fiddle 1 choke in.
Thanks for the regulator scheme Geek.
Why 2 bx's parallel, to lower the impedance?
I will use one EL84 for the whole Stereo pre-amp, the space is limited, transformer also (2 * 8V AC 1.5A and HT) Don't want to change everything.
My preamp is the upper one of:
http://img169.imageshack.us/img169/8364/setje6ms.jpg
Btw on the left a diy headphone OTL amp, made from scrap tubes, Marcon Lytics, Telefunken ECC85 + two EL95 in triode (the EL95 is the ONLY beam power penthode Philips made) The design is from myself, discovered this morning there are more of such designs: http://www.tubecad.com/january2001/page9.html
Geek
Hi Tubee,
Nope, just extra plate dissipation. You could use a 6AQ5 or 6BQ5 in there tied triode, or tied pentode with extra filtering on g2 for superb ripple reduction.
I just had a box of 12BH7's, but few little power pentodes at the time ;)
If you don't have a zener regulated bias supply, just drop your zener or VR tube in the 6CB6A cathode and ground the divider resistor.
One caveat - use 6CB6A over 6CB6 - warmup time of the "A" is faster and you won't have a few seconds of full unregulated B+ on your circuit like you would with the 6CB6.
tubee
Thanks Geek for all tips, will dig this out.
Yesterday looked for a solution for motorboating, with extra cap on PS to phono + extra resistor(from 300 to 1k) its some better but not dissapearing. It starts in the phono stage and with further turning of volume pot the whole preamp starts motorboating. Strange, in the beginning a few years ago it did'nt oscillate.
Maybe some dry lytic caps?
A new PS or regulator doesnt solve the motorboating problem in phono.
Geek
If the decoupling R is too small, all the C won't help... just make the oscillation frequency lower.
A little rule of thumb I gleaned from experiments is the decoupling R should be 1/10 the plate R of the stage. C can be 10uF or so. More is just waste in my experiments.
Here is an example for my preamp....
Plate load R's for the first phono, 270K. Second phono, 100K. Plate of my L-W CF linedriver are straight to B+ (well, through it's 330R load resistor).
Power from the raw B+ goes through 10K to the second phono and a 10uF 'lytic to ground (10K = 100K second phono load/10). From there, it goes through 27K and another 10uF bypass (27K = 270K first phono load/10).
You don't really want a "star" power point, where raw B+ goes through various decoupling resistors, but a "daisy-chain".
Perhaps illogical, but has been used by designers forever and seems so far foolproof :)
tubee
Geek i agree with small as possible decoupling caps as well. Made a SE EL84 amp with diy output-transformers. Sounded great with about 50uF supply and a choke. Later did it over with same transformers and 6V6gt's, never sounded that good anymore.
I have solved the motorboating problem The TL783 was oscillating, with a shunt R of 33 K ohm to Gnd there is more current-draw from the regulator, and it's quiet now. The phono suffered from it because the high gain.
In meantime i found an interesting supply, its from http://www.diyaudio.com/forums/show...10&pagenumber=9
tubee
A few years ago i found somewhere on the internet a shunt with a EL84, i made a drawing of it on paper. Yesterday i found the drawing again, redrawed it on the pc. Don't know from wich site it is, and don't know the part values either. Maybe with a tube-simulator the right parts could be determined. The shunt is regulating after a resistor in series with supply line, with a cap ofcourse.
Geek
Hi Tubee,
... The TL783 was oscillating, with a shunt R of 33 K ohm to Gnd there is more current-draw from the regulator, and it's quiet now....
Such a simple solution, glad you found it! :)
LM317's suffer the same thing. All them crazy little sand-device regulators need some sort of idle current, just like a choke-input filter.
tubee
Yes i am glad its solved.
Improved PS also a little: Vishay BYV96C rectifier diodes. (was 1N4007) Swapped the Large Siemens Lytic for 2 smaller ones, same capacity, higher temp rating Panasonic and other make.
The freecoming space is used for a 11W fluorescent lighting choke inbetween C's.
Page generated in 0.044111013412476 seconds with 17 queries,
spending 0.00834441 doing MySQL queries and 0.03576660 doing PHP things.
