| Tear in magnetostat membrane: What to do? - Click HERE for Original Thread |
| Klimon |
Hello,
I just made a small tear in the membrane (ultra-thin plastic sheet) of a magnetostatic tweeter - Now my question is if this rip will expand due to vibrations (what it's made for:) and should be glued (with a fine hand and close to no glue) or can be left as is without causing further damage? I can't hear any difference between the non-damaged tweeter and this one so if the damage stays as is all is fine by me. Replacement membranes aren't available anymore btw (Technics TH-400).
Thanks for any replies!
Simon |
| ThomasW |
| The front (what you see) is a layer of fiberglass over top of the mylar sheet with the copper circuit on it. Have you sliced through the fiberglass into the mylar? |
| Klimon |
| Yes, the hole goes right through the membrane. |
