diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Could you check my parts list? - Click HERE for Original Thread
maurycy
I have purchased Brian's LM3875 stereo non-inverting kit. I am also going to purchase an aluminum enclosure. My goal is not to make the unit fancy looking but to learn how to build amps since I am complete noob.
There is couple of things I need like trafo, switch, etc. I have put together a list of items from Parts Express. Could you guys check it out and let me know if I picked correct parts?
Here is the list:
Avel 250V 18V+18V toroidal transformer
http://www.partsexpress.com/pe/show...tnumber=122-620
RCA jack pair
http://www.partsexpress.com/pe/show...tnumber=090-278
Dual binding post (will need two)
http://www.partsexpress.com/pe/show...tnumber=090-475
SPST heavy duty toggle switch
http://www.partsexpress.com/pe/show...tnumber=060-370
IEC power jack chassis mount
http://www.partsexpress.com/pe/show...tnumber=090-442
I am missing a potentiometer but PE does not have dual gang pots. I will have to get it somewhere else so recommendations are welcome.
Thanks,
Alex
jaudio
Goldmine-elec.com
Pots
This one is very good for the price!
http://www.goldmine-elec-products.c...item=1&mitem=37
This one has a Noble black 10k
http://www.goldmine-elec-products.c...aitem=1&mitem=6
Power jack chassis mount
http://www.goldmine-elec-products.c...aitem=2&mitem=3
Switch
http://www.goldmine-elec-products.c...item=2&mitem=10
Apexjr.com
Rca jacks
http://www.apexjr.com/images/Bposts1.jpg
Output posts
http://www.apexjr.com/images/APEXJREMIFILTER1.jpg
Switch
http://www.apexjr.com/images/switch.jpg
You can get your misc. at apexjr
jaudio
wrong picture for rca jacks($2 a pair.
here is the right picture
http://www.apexjr.com/images/RCA3.jpg
Leolabs
Go for them.:)
Nordic
Unless you are aiming to drive 4 ohm loads, i would go for a slightly higher voltage transformer, maybe something that would give closer to 35V after rectification... (35 / 1.41 =+-25V).
So, maybe look at
http://www.partsexpress.com/pe/show...tnumber=122-625
And if you consider the 1.6V voltage drop through the chip itself, one could go even higher.
Narcisse91
I don't see a fuse holder and fuses on any of those lists...
Something like this:
http://www.partsexpress.com/pe/show...tnumber=071-510
maurycy
Thanks guys.
I will place an order this week. It is shame that Parts Express does not have dual gang pots. I will have to pay more for shipping of one item than the cost of the item alone.
Alex
Nordic
Also look at suppliers like http://www.rs-components.com/index.html . My local branch is so close I can collect my stuff and save on haveing to pay shipping.
Page generated in 0.033143043518066 seconds with 17 queries,
spending 0.00820494 doing MySQL queries and 0.02493811 doing PHP things.
