diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Parallel lm386 - Click HERE for Original Thread
joecool85
Thats right, not lm3886, but lm386. I'd like to drive a pretty small 4 ohm speaker with a couple lm386's. I know that they are good for 8 ohms, so running them in parallel should be fine for 4 ohms. Problem is, I don't know how to parallel chips lol. Any ideas?
neutron7
well it can power 4 ohms by itself. not very well or anything but it can do it. just try one and hook it up to the 4 ohm and see if it will go loud enough for your application.
if you want to try to parallel them try to just build 2 the same and connect each output to the speaker output capacitor through a resistor. I am not sure what value yiou need for a little amp like that. 0.1 ohm is common for lm3886 in parallel . they may run a bit wermer though you might want to stick some ramsinks on there.
joecool85
Ram sink?
neutron7
little heatsinks that PC modding stores sell to stick to the RAM chips on video cards. they are of questionable use in that aplications but can cool any IC a bit.
any chunk of aluminium that fits on there ought to help.
EWorkshop1708
With paralleling LM386 chips, you can use 0.1-0.5 ohm output resistors with no problem. But LM386 is rather weak chip for any real power, but they still go nice and loud.
***However, DON'T bridge LM386***
I did that using 5 and 12V to run the 2 LM386 IC chips. Used an 8 ohm speaker and bridged. Even with only 5V, it played very loud, but ran warm. When I bridged with 12V it played extremely loud, but after 15 seconds the chips got hot and blew! lol :hot:
Instead of LM386, why not use a better chip that can safely drive 4 ohms with a decent amount of power? Even if you are using 6V or so of supply, a typical car audio IC will do fine.
Most car radio IC can drive 2 ohms/channel, or 4 ohms bridged. Much better IMO.
joecool85
Do you have a good example of a car audio IC that I could easily get a hold of?
Also, this thing doesn't need to be a screamer, just enough sound to play an electric bass through at low levels. Roughly speaking level. Using one lm386 on an 8 ohm load proved plenty loud for guitar.
EWorkshop1708
A chip I'm about to use for an amp project is the AN7147 which is 5W/channel @ 12V 3 ohms. I'm using this to boost the output of my soundcard for a stereo headphone amp :eek: and to drive small computer speakers too. The IC manufacturer says you can run without a heatsink if not putting out much power, but I'd still recommend a heatsink, even if it's just a flat piece of metal.
AN7147 DATASHEET: http://www.datasheets.org.uk/search...&ExactDS=Starts
This website has them for $1.40 a piece:
http://www.futurlec.com/Sanyo/AN7147pr.shtml
Also, since it's a 2 channel chip, you can parallel the two channels on the chip to drive 1.5 ohms :D
N-Channel
Joe,
Try NEC's mPC1230H2. I use to use this chip until I graduated SMPS-powered discrete Amplifiers.
I believe the old Alpine3505 (2-channel)and 3510 (4-channel)Amps used this chip. It is rated at 13W into 4W at 14.2V. Many of Alpine's old-old school (1980s) head units also used this chip. It is has BTL (Bridged Transformer-Less) output that enables the 13W rating.
I used a number of them to drive some Radio Shack Minimus-7s with exceptional results. The bass was strong and tight, the highs were crisp but not too bright, and the midrange was very full of presence- an all-around great chip to use.
I think they can still be ordered from Parts Express or MCM Electronics. for about $5-7 each.
Hope this helps,
Steve
N-Channel
Well, I just looked at MCM's catalon-online, and they're........discontinued. :bawling: too bad. These were great chips. NTE's version (NTE1389) might still be available somewhere....
EWorkshop1708
quote:
NTE is overpriced.................
Being that he's only playing with simple chips, that's why I told him to go with AN7147, because it's just as easy to hook up as a LM386, nearly as cheap too, and they are still available, and it does not require much heatsinking. Also does not need any resistors other than 2.2ohm/0.1uf zobel network.
If he's wanting some real power from 12V, he could always get one of those 50W max BTL Car radio chips :eek: :hot:
triden
What I would probably do instead of paralelling the chips is make a simple push-pull current gain stage on the output using 2 bjt transistors. This way you are limited only to the amount of current that the transistors can provide. Adding a small single output stage would be a fairly easy to do.
Page generated in 0.046303987503052 seconds with 17 queries,
spending 0.01318884 doing MySQL queries and 0.03311515 doing PHP things.
