diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
microphone impedance detector - Click HERE for Original Thread
dypotts
I need a circuit or a technique for detecting if an electret mic or dynamic mic is connected to the amp input to make appropriate gain adjustments. I thought about sensing the voltage and using comparators to control switches across gain resistors. Any ideas?
Nigel Goodwin
quote:
What's wrong with a volume control?.
The outputs from microphones tend to be fairly similar, and the normal input controls do all that's required.
What are you trying to do?.
Page generated in 0.01644492149353 seconds with 17 queries,
spending 0.00690150 doing MySQL queries and 0.00954342 doing PHP things.
