| IR/UV Filter (Hot Mirror), Large improvement over Lexan - Click HERE for Original Thread |
| Whatmo |
Do you want something that doesn't absorb as much visible light as lexan does? Or maybe just something that blocks out more of the harmful infared and ultraviolet light, I wanted more...
And I just recieved 10 uv/ir colour filters. I am using one of them so I have 9 left over.
They are 4"x4" square pieces of glass. If you would like one email me at graham@whatmough.Ca. I can sell them for $50CAD + whatever shipping to you cost. I may get more of these for you if there is a good response to these. I will post a full spec sheet once I get it from the supplier, it should be within the next day.
Here is a link of a similar item:
http://cgi.ebay.com/77mm-IR-UV-bloc...bayphotohosting |
| Whatmo |
| Here are the specs I promised. As you can see this filters out most harmful light and passes approximately 90% of the visible light. |
| Whatmo |
| Here is a picture of the filter itself. |
| Whatmo |
| I currently don't have any of these available now since I am using them for kits guys at work want me to put together. But if you still want one let me know and I can get more within a week. |
| Whatmo |
Hey
I have been busy converting my diy projector from front projection into a 60" rear projection. My image was flipped left to right so this will solve that problem. It should also make it about 3-4 times as bright since it will be smaller.
A few people have contacted me about the UV/IR Filters so I bought some more. I bought a few more this time so I was able to get a discounted rate. If you would like to get one of them I can sell them to you for $35 CAD ($30USD). Thanks for the interest. |
| Whatmo |
Hey
I just got the fabric I needed to make the rear projection screen. I just need to go and get some pine 1x4 to make the frame now. I am going to put my projector in a closet and have the screen hanging from the ceiling about 3ft from the projector. I should have it all done by the weekend and I will put some pictures up. |
| Whatmo |
| Well, its all done and looks great. I would put some picutres up but the usb calbe doesn't work. I will just have to get a card reader or something I guess. |
| Whatmough |
Hey after a long absence I am back and am working on my projector again.
I still have 6 or 7 of these filters if anyone wants one. I had to get a new login name since I forgot the password for my old one. I also started a new thread about these filters. Tell me what you think about them.
http://www.diyaudio.com/forums/show...&threadid=94763 |
