diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
help me design a PWM circuit - Click HERE for Original Thread
tade
I am gonig to try and make a project which will mix the light from R,G, and B leds as a color mixing experiment. I would like to drive each led with a constant voltage but pulse them to achieve a variable brightness. I want the bass frequency to be 30 pulses per second and the width to vary from zero to 1/30 second. I would like for it to be controlled by a knob and to have a meter which will read pulse width or maybe even intensity. Or it could just read pulse width and I could devise a formula to relate the two.
I think a 555 timer could provide the 30 pulses per second, and have a RC circuit to adjust the pulse width. The voltage from the cap could go to a transistor which would act like a switch switching whatever voltage i select for the LED.
help me from here!
Thanks!
Page generated in 0.015892028808594 seconds with 16 queries,
spending 0.00800753 doing MySQL queries and 0.00788450 doing PHP things.
Please support our sponsor.
