diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
"japanese" Transistors To "european" - Click HERE for Original Thread
MYLEY
Hello.Does anybody know if there is a conversion table to convert "JAPANESE" transistors to "EUROPEAN".I have a Toyota radio from a Japanese import and need a surface mount transistor with the markings "BC QU".
dnsey
There always used to be 'equivalents books', but I don't know if there are any covering SM devices. Just look up the parameters, and find a match via data sheets.
MYLEY
Thanks.I have tried entering markings on various sites to identify the component,but to no avail.I have also contacted Nikko-Electronics but they to are unaware of such a component,as are CPC.I wonder if the markings,BC QU,is a code used by Sony,or in this case, Fujitsu Ten?I have noticed that Sony tend to use components with similar markings,does anybody know what the markings refer to?Thanks.
AndrewT
I believe the two and three digit numbers are simply manufacturer codes, probably intended for mass production.
Since most will be buying on a 5000 reel the code just confirms that they have the labelled reel correctly loaded on the assembly machine.
I would not expect these codes to be unique, there are just too few digits.
You will need the manufaturer and chip name to identify the type.
Onra
Do you have a picture available (with readable marking, if possible)?
Same marking may be used for different devices in different packages.
Without package size youŽll hardly find the corrct device.
Onra
Page generated in 0.043760061264038 seconds with 16 queries,
spending 0.02906609 doing MySQL queries and 0.01469398 doing PHP things.
