diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Wiring Charlize - Click HERE for Original Thread
neil_kaye
I recently recieved a Charlize pre-wired. Everthing look sgreat except i am slightly confused about one thing.
Ther is a shielded cable that runs to the left adn right in, It terminates with 4 wires. Two coded white that go the left in and right in. Two yellow that appear to run straight from the grounds and atatched to the shielding. Ho woudl i wire this configuration to the RCA's (left and right on the free end) as only the two whites runt eh length of the cable.
Would i run two wires from the RCA grounds to the shielding or is there something i am missing here?
vt4c
Neil,
The shield wire should be connected to the RCA ground.
Page generated in 0.020802021026611 seconds with 16 queries,
spending 0.01151109 doing MySQL queries and 0.00929093 doing PHP things.
