diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Pages: [1] 2 3 4 5 6 7
A twisted tale about a logarithmic relay attenuator - Click HERE for Original Thread
Russ White
Twisted Log Attenuator:
A few weeks ago I began studying my options when I really needed a great attenuator to match my new Twisted XBOSOZ preamplifier. I really did not want to have to solder a lot of resistors around a rotary switch and wanted to be able to easily handle balanced signals.
Well I searched and searched and found a lot of really cool relay switched attenuators, which very much appealed to me, I really wanted a true logarithmic approach, one switch on, one logarithmic step. Most of the examples I found where either R-2R or a string of switches like a rotary attenuator. Those are great, but not exactly what I wanted right now. Still, since I was in the mood to experiment I built an R-2R ladder attenuator which further fueled the desire to push even further, as it worked very well indeed.
So, I found a site developed by Jos van Eijndhoven which was a wonderful resource for me. Jos is very generous to have shared so much great information on his site. He also has a very cool implementation of his own which I think is superb. The site can be found here at :
http://jos.vaneijndhoven.net/switchr/index.html
At the site you can read all about the approach I chose, which is a logarithmic ladder, or as some have called it a 7 bit addressable LPAD register, which makes sense too. In fact that is pretty much how it works. The output impedance of the circuit is constant while the input impedance varies. This is very desirable for some circuits as change output impedance can change change input characteristics of the target circuit, this can be a less than desirable thing. But the biggest win is that you get a nice truly logarithmic curve with steps precisely as you design them.
This project is an open project. Everything I have done is public domain knowledge and I intend to share the design, PCB PDFs, schematics, and experiences freely with the hope that some will be able to contribute and make the design better, and that some will be able to do something they might not have otherwise attempted.
I won't try to rewrite all the good information on Jos' site instead I will explain what I have done to implement what I have learned.
First of all I wrote a small Java application to generate the resistor values for me, and determine the closest E96 resistor value for each resistor in each stage. I will post it later after I polish it up a bit.
Then I designed a PCB which would allow me to build the circuit with a lot of flexibility. My best success so far has been to calculate the first stage as if it has a perfect source, or if you know the actual output impedance of the source you can plug that in too, but in most cases the input impedance is low enough to be dominated be the first stage, so not knowing the exact value is just fine. The circuit I designed is for 7 relays which works out great for .5db step from -63.5db to 0 db attenuation.
If you have a very high output impedance source like a tube DAC or something you could do a couple of things, you can calculate the first stage for the actual output impedance of the source (which is the input impedance to the attenuator) or you could use a buffer in front of the attenuator and calculate for a (nearly) perfect source.
For my own initial implementation and for the purposes of providing a springboard for further development I designed a simple firmware application for my circuit and a controller PCB for it. This controller is very simple which should help people who just want a simple attenuator, and not a lot of bells and whistles. The human interface is a simple linear single pot (5-20K is fine) which does not need to be anything fancy at all, no signal goes through it. The micro controller is a PIC16F690 of which I am only using a small number of the I/O pins (8) leaving the others for other things like display, mute, or whatever you like. The pot is attached on one end to VCC and to the other VSS and the ADC on the PIC reads the voltage at the wiper in reference to VCC and sits the 7 bit relay register based on the value returned by the ADC.
That controller worked very well, and work very much like a standard LOG audio pot. A very conventional and useful controller implementation. :)
Now, there are some tricks I used in the firmware to get past a few things. First, if you progress upward through the 7 bit register from 0 to 128 you will notice as get reach the more more significant bits as that high bit turns on (or off in the downward progression) and all of the bits below it turn off (or on) the input impedance will jump (or fall) significantly which leads to an annoying pop. Not to worry, there was a very simple way to address this in the firmware. The little G6K relays I am using switch pretty dang fast. :) So I was able to switch off (or on) the relays below the most significant on(or off) one at a time till I only have one of them on (which matches the input impedance roughly of the significant bit I am transitioning to), then I set the significant bit. Pop is then totally eliminated, and it happens so fast (a few ms) you don't notice it. The firmware code (C code) will be posted here soon so you can see how I did it.
So the bottom line is this logarithmic attenuator works very well, I would venture its as good as the best and better than the rest. ;) You can use nice resistors, and the soldering is easy. Both channels can be matched perfectly, so you get perfect channel matching. Give it a try I think you will find what I have, your new attenuator. :cool:
Some other details. The PCBs I am providing are single sided and easy to etch. Also they are the same size (controller and attenuator PCBs are separate) and designed to be stackable so you can easily do balanced (2 attenuator boards and one controller) or SE (one of each) and not take up much case real estate at all.
More details and PCB and schematic images coming soon (today) just tidying them up.
Cheers!
Russ
Russ White
Here is the simple controller:
You can of course make you own as complex as you like. :)
Russ White
Here is a list of resesitor values for a 2.2K impedance between stages:
db attenation = -0.5 -- R IN = 0 - R OUT = 2200
R1 = 2330(2320) OR (2320 + 10), R2 = 39328(39200) OR (39200 + 127), R3 = 0(0) OR (0 + 0)
db attenation = -1.0 -- R IN = 2200 - R OUT = 2200
R4 = 268(267) OR (267 + 0), R5 = 0(0) OR (0 + 0), R6 = 20230(20000) OR (20000 + 232)
db attenation = -2.0 -- R IN = 2200 - R OUT = 2200
R7 = 570(576) OR (562 + 0), R8 = 0(0) OR (0 + 0), R9 = 10697(10700) OR (10500 + 196)
db attenation = -4.0 -- R IN = 2200 - R OUT = 2200
R10 = 1287(1300) OR (1270 + 16), R11 = 0(0) OR (0 + 0), R12 = 5961(5900) OR (5900 + 61)
db attenation = -8.0 -- R IN = 2200 - R OUT = 2200
R13 = 3326(3320) OR (3320 + 0), R14 = 0(0) OR (0 + 0), R15 = 3655(3650) OR (3650 + 0)
db attenation = -16.0 -- R IN = 2200 - R OUT = 2200
R16 = 11681(11800) OR (11500 + 182), R17 = 0(0) OR (0 + 0), R18 = 2614(2610) OR (2610 + 0)
db attenation = -32.0 -- R IN = 2200 - R OUT = 2200
R19 = 85384(84500) OR (84500 + 887), R20 = 0(0) OR (0 + 0), R21 = 2257(2260) OR (2210 + 46)
chipco3434
This will be used as an OUTPUT attenuator, correct?
Russ White
quote:
It could be used either way. I will probably use mine on input.
Russ White
Vout/Vin[dB] Vout/Vin[ratio] Rin Rout Q1 Q2 Q3 Q4 Q5 Q6 Q7
-63.54048 6.6523615E-4 5414.239 2203.1501 0 0 0 0 0 0 0
-63.041058 7.046073E-4 5549.779 2203.1501 1 0 0 0 0 0 0
-62.53672 7.467308E-4 5665.7983 2203.1501 0 1 0 0 0 0 0
-62.037292 7.90925E-4 5848.384 2203.1501 1 1 0 0 0 0 0
-61.533173 8.38188E-4 5805.4966 2203.1501 0 0 1 0 0 0 0
-61.033745 8.8779506E-4 6016.024 2203.1501 1 0 1 0 0 0 0
-60.529118 9.409013E-4 6218.407 2203.1501 0 1 1 0 0 0 0
-60.029694 9.965873E-4 6519.28 2203.1501 1 1 1 0 0 0 0
-59.49919 0.0010593523 5906.695 2203.1501 0 0 0 1 0 0 0
-58.999763 0.0011220488 6138.2847 2203.1501 1 0 0 1 0 0 0
-58.49507 0.001189177 6365.61 2203.1501 0 1 0 1 0 0 0
-57.995644 0.001259557 6701.5493 2203.1501 1 1 0 1 0 0 0
-57.4944 0.0013343813 6765.389 2203.1501 0 0 1 1 0 0 0
-56.994976 0.0014133549 7204.356 2203.1501 1 0 1 1 0 0 0
-56.48978 0.0014979971 7691.434 2203.1501 0 1 1 1 0 0 0
-55.990356 0.0015866541 8414.698 2203.1501 1 1 1 1 0 0 0
-55.542675 0.0016705764 5730.0405 2203.1501 0 0 0 0 1 0 0
-55.043247 0.0017694472 5925.3125 2203.1501 1 0 0 0 1 0 0
-54.538673 0.001875281 6109.8125 2203.1501 0 1 0 0 1 0 0
-54.039246 0.001986267 6385.787 2203.1501 1 1 0 0 1 0 0
-53.53703 0.0021044982 6406.4243 2203.1501 0 0 1 0 1 0 0
-53.0376 0.0022290503 6752.3574 2203.1501 1 0 1 0 1 0 0
-52.5326 0.0023624902 7119.857 2203.1501 0 1 1 0 1 0 0
-52.033176 0.0025023108 7659.9478 2203.1501 1 1 1 0 1 0 0
-51.50073 0.0026605024 6969.424 2203.1501 0 0 0 1 1 0 0
-51.0013 0.0028179605 7465.4565 2203.1501 1 0 0 1 1 0 0
-50.496006 0.0029867562 8028.1826 2203.1504 0 1 0 1 1 0 0
-49.99658 0.0031635235 8871.424 2203.1504 1 1 0 1 1 0 0
-49.500164 0.0033495908 9357.07 2203.1501 0 0 1 1 1 0 0
-49.00074 0.003547832 10767.108 2203.1501 1 0 1 1 1 0 0
-48.49459 0.0037607152 12752.872 2203.1501 0 1 1 1 1 0 0
-47.995163 0.0039832885 16406.893 2203.1501 1 1 1 1 1 0 0
-47.52965 0.004202594 5455.292 2203.15 0 0 0 0 0 1 0
-47.030224 0.004451319 5598.225 2203.15 1 0 0 0 0 1 0
-46.525856 0.0047174497 5722.5825 2203.1501 0 1 0 0 0 1 0
-46.02643 0.0049966457 5916.3677 2203.1501 1 1 0 0 0 1 0
-45.522568 0.0052950694 5880.8306 2203.1497 0 0 1 0 0 1 0
-45.02314 0.005608451 6106.971 2203.1497 1 0 1 0 0 1 0
-44.518463 0.005943973 6327.8164 2203.1497 0 1 1 0 0 1 0
-44.019035 0.0062957597 6654.6074 2203.1497 1 1 1 0 0 1 0
-43.48827 0.006692472 6032.284 2203.1501 0 0 0 1 0 1 0
-42.988846 0.0070885564 6290.9834 2203.1501 1 0 0 1 0 1 0
-42.484066 0.007512711 6550.826 2203.1501 0 1 0 1 0 1 0
-41.984642 0.007957341 6933.0684 2203.1501 1 1 0 1 0 1 0
-41.48406 0.00842941 7031.408 2203.1494 0 0 1 1 0 1 0
-40.98463 0.008928293 7545.3887 2203.1494 1 0 1 1 0 1 0
-40.479305 0.009463128 8132.257 2203.1494 0 1 1 1 0 1 0
-39.97988 0.01002319 9014.441 2203.1494 1 1 1 1 0 1 0
-39.532223 0.0105533125 6033.045 2203.1494 0 0 0 0 1 1 0
-39.0328 0.0111778965 6291.9116 2203.1494 1 0 0 0 1 1 0
-38.52802 0.0118467435 6551.957 2203.1497 0 1 0 0 1 1 0
-38.028595 0.012547878 6934.4893 2203.1497 1 1 0 0 1 1 0
-37.528015 0.0132922735 7033.0483 2203.1475 0 0 1 0 1 1 0
-37.028587 0.014078959 7547.508 2203.1475 1 0 1 0 1 1 0
-36.523262 0.014922337 8135.0225 2203.1477 0 1 1 0 1 1 0
-36.023838 0.015805496 9018.254 2203.1477 1 1 1 0 1 1 0
-35.489716 0.016807932 8247.292 2203.1504 0 0 0 1 1 1 0
-34.990288 0.017802687 9173.5625 2203.1504 1 0 0 1 1 1 0
-34.484474 0.01887019 10358.326 2203.1511 0 1 0 1 1 1 0
-33.98505 0.019986996 12302.223 2203.1511 1 1 0 1 1 1 0
-33.49279 0.02115244 13957.52 2203.145 0 0 1 1 1 1 0
-32.993366 0.02240432 18741.518 2203.145 1 0 1 1 1 1 0
-32.486397 0.023750905 29405.879 2203.1462 0 1 1 1 1 1 0
-31.98697 0.02515657 89837.37 2203.1462 1 1 1 1 1 1 0
-31.552883 0.026445746 5414.467 2196.8567 0 0 0 0 0 0 1
-31.053457 0.028010903 5550.048 2196.8567 1 0 0 0 0 0 1
-30.54912 0.029685475 5666.1133 2196.8584 0 1 0 0 0 0 1
-30.049694 0.03144237 5848.7603 2196.8584 1 1 0 0 0 0 1
-29.545572 0.033321258 5805.913 2196.8435 0 0 1 0 0 0 1
-29.046148 0.03529333 6016.526 2196.8435 1 0 1 0 0 0 1
-28.541521 0.03740451 6219.0093 2196.8464 0 1 1 0 0 0 1
-28.042095 0.03961825 6520.0225 2196.8464 1 1 1 0 0 0 1
-27.511591 0.042113412 5907.3833 2196.8618 0 0 0 1 0 0 1
-27.012165 0.04460584 6139.119 2196.8618 1 0 0 1 0 0 1
-26.50747 0.047274455 6366.6177 2196.8665 0 1 0 1 0 0 1
-26.008045 0.050072327 6702.803 2196.8665 1 1 0 1 0 0 1
-25.506805 0.053046867 6766.823 2196.8284 0 0 1 1 0 0 1
-25.00738 0.056186378 7206.18 2196.8284 1 0 1 1 0 0 1
-24.502182 0.059551246 7693.77 2196.836 0 1 1 1 0 0 1
-24.002758 0.06307571 8417.835 2196.836 1 1 1 1 0 0 1
-23.555077 0.06641194 5731.6523 2196.8345 0 0 0 0 1 0 1
-23.05565 0.07034245 5927.2466 2196.8345 1 0 0 0 1 0 1
-22.551075 0.074549764 6112.1226 2196.8462 0 1 0 0 1 0 1
-22.05165 0.07896189 6388.618 2196.8462 1 1 0 0 1 0 1
-21.54944 0.08366195 6409.6235 2196.7512 0 0 1 0 1 0 1
-21.050014 0.088613376 6756.3447 2196.7512 1 0 1 0 1 0 1
-20.54501 0.093918145 7124.8374 2196.77 0 1 1 0 1 0 1
-20.045584 0.09947657 7666.416 2196.77 1 1 1 0 1 0 1
-19.513126 0.10576542 6975.477 2196.8672 0 0 0 1 1 0 1
-19.0137 0.112025 7473.2495 2196.8672 1 0 0 1 1 0 1
-18.508402 0.118735306 8038.309 2196.897 0 1 0 1 1 0 1
-18.008978 0.12576249 8885.3 2196.897 1 1 0 1 1 0 1
-17.512585 0.13315907 9374.382 2196.6562 0 0 1 1 1 0 1
-17.013159 0.14103991 10792.838 2196.6562 1 0 1 1 1 0 1
-16.507006 0.14950293 12793.462 2196.7039 0 1 1 1 1 0 1
-16.00758 0.15835106 16482.365 2196.7039 1 1 1 1 1 0 1
-15.5420885 0.16706888 5464.553 2196.464 0 0 0 0 0 1 1
-15.042664 0.17695662 5609.17 2196.464 1 0 0 0 0 1 1
-14.538286 0.18753645 5735.4307 2196.5388 0 1 0 0 0 1 1
-14.038861 0.19863553 5931.78 2196.5388 1 1 0 0 0 1 1
-13.535057 0.2104976 5897.9365 2195.9375 0 0 1 0 0 1 1
-13.035631 0.22295563 6127.6763 2195.9375 1 0 1 0 0 1 1
-12.530941 0.23629414 6352.799 2196.0562 0 1 1 0 0 1 1
-12.031515 0.2502789 6685.6265 2196.0562 1 1 1 0 0 1 1
-11.500689 0.2660514 6061.0894 2196.6704 0 0 0 1 0 1 1
-11.001264 0.2817973 6326.159 2196.6704 1 0 0 1 0 1 1
-10.496467 0.29865974 6593.7095 2196.86 0 1 0 1 0 1 1
-9.997041 0.31633553 6987.0225 2196.86 1 1 0 1 0 1 1
-9.496606 0.33509636 7093.7495 2195.336 0 0 1 1 0 1 1
-8.997181 0.35492858 7626.0723 2195.336 1 0 1 1 0 1 1
-8.491825 0.37619132 8237.782 2195.6367 0 1 1 1 0 1 1
-7.9923987 0.3984557 9160.366 2195.6367 1 1 1 1 0 1 1
-7.544749 0.41952956 6105.202 2195.5796 0 0 0 0 1 1 1
-7.0453224 0.4443589 6380.1377 2195.5796 1 0 0 0 1 1 1
-6.5404983 0.4709503 6659.6753 2196.051 0 1 0 0 1 1 1
-6.041073 0.49882287 7070.277 2196.051 1 1 0 0 1 1 1
-5.54086 0.5283929 7190.205 2192.2615 0 0 1 0 1 1 1
-5.041435 0.55966514 7751.484 2192.2615 1 0 1 0 1 1 1
-4.536036 0.593196 8402.759 2193.0093 0 1 1 0 1 1 1
-4.03661 0.6283035 9390.366 2193.0093 1 1 1 0 1 1 1
-3.5021136 0.6681813 8599.741 2196.8816 0 0 0 1 1 1 1
-3.0026882 0.7077267 9668.007 2196.8816 1 0 0 1 1 1 1
-2.496758 0.75017416 11077.018 2198.0776 0 1 0 1 1 1 1
-1.9973323 0.79457223 13466.366 2198.0776 1 1 0 1 1 1 1
-1.506002 0.84081393 15679.786 2188.4722 0 0 1 1 1 1 1
-1.0065768 0.89057636 22457.365 2188.4722 1 0 1 1 1 1 1
-0.49942598 0.94412327 41520.0 2190.366 0 1 1 1 1 1 1
-5.177194E-7 0.99999994 1.0E9 2190.366 1 1 1 1 1 1 1
Copy and paste it into Excel or open office Calc to get a good look at impedance and the attenuation curve.
SheldonD
Russ:
Very, very nice.
You need to change you spelling on the board to twisted pair
not tswited pair! it kinda of looks like twitted pair.
steenoe
Russ, That is impressive work indeed:) My goodness:cool: To be honest, I never saw something like it:) Congrats!!! Very nice writeup on the subject:)
Steen:cool:
Russ White
Thanks Sheldon, Fixed.
steenoe
Ha-ha You need to spell like this: "Order your kit here" :D :D
Steen:)
SheldonD
Russ I can see where this could/might apply to more than 2 channel stereo
say 5, 6 or 7 would iit be possible/feasible to incorporate a sort of preset to each channel? i.e. boost or attenuate each channel independently of overall loudness?.
This would ideally be done through software in your programamable modules.
I realize this is an order of magnitude leap ahead of what you just proposed.
moamps
quote:
Originally posted by SheldonD
[B]Russ I can see where this could/might apply to more than 2 channel stereo
... and the balance feature.;)
SheldonD
Yes,
essentially what i asked about is a balance function across channels not jsut stereo.
apassgear
Excellent approach Russ, I like the idea of a simple attenuator.:cool:
I would suggest too keep it as simple as possible as you have. As soon as you start adding functions and complexity to the circuit some of us (me included) will shy away from building it.
I guess many on the forum are not digital inclined and have never programmed a PIC (me included once again). So what are the alternatives for those of us at the digital end?
choky
quote:
buy it as a kit?
Russ White
Hi Sheldon,
Certainly, there are a host of things anyone so inclined could do with a controller in the firmware. I will explore some ideas later on in the thread and probably supply some code and layouts to help people out. :)
Cheers!
Russ
Russ White
Thanks Tony, Coming from you that means a lot to me.
I am still in many ways just a beginner here, so having some little bit of success here really makes me feel great. :)
As for the PIC programming I am going to be posting a layout for a simple serial port programmer I did which is based on the "RCD" PIC programmer. Very simple to use with open source free software. Once you have that and the HEX code all you need are the PICs to program. :)
Alternatively, as Choky said Brian and I may well decide to sell some of these as kits. Have not made any hard fast decissions yet.
Cheers!
Russ
Byrd
Hey Russ - Looks good. Advantages over the Kooka - which by the way sounds absolutly transparent to my ears.
NUdge Nudge, Wink Wink * This almost seems like it could pretty easily be converted into a source selector - and extending it to include an LCD display shouldn't be to far off :D
mpmarino
Oh Russ, I knew you could do it! Nice work and an answer that a LOT of peeps are looking for.
Hmm, I wonder if my WILLEM programmer can program that pic thingy...it's not listed. but others like it are... Any idea? I've only used it for eproms to make ellicit:) DVD players
later...
promitheus
The attenuator looks great.
The pads and holes though for the resistors look a bit small.
Bigger pads are easier to solder.
Will the pcbs be double sided with vias or single sided?
It looks like single sided to me so maybe larger pads are a good idea.
Using the DAC with the a normal pot is also a good idea because there is know need for a display.
I also like the idea of a 7bit control because its more stable and not so many steps. 6 would also would be ok.
The relays are very good. I think one could also use others but I am not so sure how universal they are.
If the input selection is also so simple and good I will be surely using them.
A mute Relay would be helpful to make a time delay on turn on etc.
Russ White
Hey guys disregard the first layout I posted, it actually has a couple problems, and I am working on a much better one.
Here is the plan. I will be posting PDFs for a single side version(actually a few versions) and Brian and I will likely produce kits for a more optimized double side version(s).
Cheers!
Russ
promitheus
That sounds great !
I cant wait to see the new boards.
apassgear
quote:
A mute relay would be a nice addition if Russ decides to it, an easy addition if space allows. The board looks quite crowded as is so let’s hear if this is possible.
Russ White
A mute relay (optional when stuffing the PCB) will be on the new PCB. Stay tuned. :)
herm
Russ,
I was looking at the pic board again. Naturally, I am IMpatiently awaiting the kit. Or at least the boards.
Anyway, I have a few requests that would make your boards more flexible for DIY use:
1. Can you wire all 18 outs to resistor/FET output Pads?
2. Can you add an ICSP header?
3. Can you make the unused portion of the board into vector board? Or better yet, Proto space with power & ground lines, and trace connected pads for easy circuit addtion?
4. How about a Crystal mounting spot?
Actually, I think making the spareboard into proto space would solve all issues. I could easily add anything I want! The possibilities are endless!
FYI, I have never done any PIC or PCB stuff, so my comments may be complete newbie drivel. Feel free to say "Objections Noted" and ignore me if I'm full of BS!
herm
mpmarino
I just thought of another advantage of this set up. Because it uses a pot instead of an encoder, it can be retrofitted into almost any piece of gear with a pot. Just put it in line.....minimally invasive. Pretty cool!:D
BrianDonegan
Hmmm. That's a pretty good freakin' idea!
Wait, I meant, yeah, we thought of that... :clown:
Russ White
Note IDC connectors and only six jumpers. :)
There are pads for all the available pins on the PIC and one each for GND and +5V. :)
It sounds great, with clean/smooth volume transitions. :yes:
The two PCbs are designed to be stacked, but I don't have the correct standoffs right now (on order). But even side by side they are smaller than a standard CD case.
Cheers!
Russ
Russ White
Here is the schematic, easy as pie. :D
Nordic
...if you know how to make pie of course, with nice PIC sauce.
davidsrsb
I would like to try this with a 48-24-12-6-3-1.5-0.75 sequence giving 96dB range, 64dB is not really enough range.
7 x 5V telecom relays would draw a lot of current, typically these each have a coil resistance of about 100R. 24V relays are over 2k5, so in my old Cambridge C70 preamp I think that 24V relays would be better as the raw dc is about +/- 25V. The microcontroller consumption is negligible.
promitheus
The omron Relays use very little currect.
Russ White: if you use those flat cable connectors you can easily stack the boards on top of each other and make one cable for all.
Those connectors should be universal so anybody can there own cables.
Everything looks great.
thomasfw
Are we going to use "16 pins IC" type relay ?
Thomas
BrianDonegan
The prototype uses Omron G6K 5V relays, which draw on the order of 20-30mA each. Not much at all. These are DPDT 8-pin relays.
Russ White
Yep, that was the idea. :D
Thanks!
Russ White
quote:
Easy enough. I will post some possible values for you later.
The G6K draw tiny amunts of current. With all rleays on the entire circuit draws less than 250ma.
Cheers!
Russ
Russ White
OK folks,
Here is a basic PCB layout as promised. It does 128 steps from -63.5 to 0 db attenuation.
TLA_1_0.zip
The controller is the basic controller, with just the potentiometer to ADC volume control, but I added pads for all unused PIC IO pins, and one each for GND and +5V.
You will need:
    7 G6K-2P relays
    7 BC546A or equivalent, many different NPN transistors will work fine
    20 pin Dip socket (in case you want to reprogram your PIC)
    PIC16F685,16F687,16F689,or 16F690 (I used the PIC16F690)
    A PIC programmer (I have included in the ZIP PDFs for a reasonably good one).
    7 1K resistors for the IO pins to the transistors
    4 screw terminals – 2 position, 5mm pitch
    2 2x7 pin headers. I used shrouded IDC type.
    2 2x7 IDC connectors.
    A short length of 14 conductor IDC ribbon cable
    Some good hookup wire for the jumpers between the pads on the attenuator PCB.
Double everything for a balanced pair.
Below is the resistor list for 1.5K output impedance which results in an input impedance range from 3698 to 61296 ohms. If you want to you could flatten this out a bit by placing a 10K resistor between signal IN and GND.
R1 1580
R2 26700
R4 182
R6 13700
R7 392
R9 7320
R10 887
R12 4020
R12S 88.7
R13 2260
R15 2430
R15S 53.6
R16 7870
R16S 82.5
R18 1780
R19 57600
R19S 665
R21 1540
You will notice that in some places there is a R# and R#S resistor listed. That is because to get the optimal value two resistors in series should be used. The PCB is designed to accommodate those resistors. If you wish you can omit the low value resistor and simple jumper the omitted resistor, but you will lose some linearity.
This should be sufficient for those of you who have just want to get a simple attenuator going. I am currently starting an integrated “My Ref” Revision C amplifier project using this attenuator. And I will likely use that same values for my Twisted XBOSOZ. I will post some other versions later (with mute and such) but I would not hesitate to build this version, as -63.5 db is almost as good as full mute. :)
Have a lot of fun, and feel free to ask questions.
The HEX file for the PIC is included in the zip.
The programmer is based on the RCD programmer by FENG3 which you can read more about here:
http://feng3.cool.ne.jp/en/rcd.html
I made space for the TEXTOOL type 20 pin ZIF socket on the PCB which works great for me.
And I use the PICPgm software you can find here:
http://www.members.aon.at/electroni...cpgm/index.html
When using PICPgm the RCD will work as a JDM programmer, that is what you want.
I am using the HI-TIDE IDE and PICC Lite (free) to develop my firmware.
http://www.htsoft.com/products/PICClite.php
Cheers!
Russ
Russ White
Here are some resistor values for 1.5K output impedance and .75db steps from -95.25db to 0db
Rin:0 Rout:1500 -db:-0.75
R1: 1635.28 R2: 18132.57 R3: 0
E96 R1: 1650 R2: 18200 R3: 0
E96S R1: 1650 & R1S: 0 R2: 18200 & R2S: 95.3 R3: 0 & R3S: 0
E96S Totals R1: 1650 R2: 18295.3 R3: 0
Rin:1500 Rout:1500 -db:-1.5
R4: 282.75 R5: 0 R6: 9457.47
E96 R4: 280 R5: 0 R6: 9310
E96S R4: 280 & R4S: 0 R5: 0 & R5S: 0 R6: 9310 & R6S: 54.9
E96S Totals R4: 280 R5: 0 R6: 9364.9
Rin:1500 Rout:1500 -db:-3.0
R7: 618.81 R8: 0 R9: 5136.03
E96 R7: 619 R8: 0 R9: 5110
E96S R7: 619 & R7S: 0 R8: 0 & R8S: 0 R9: 5110 & R9S: 27.4
E96S Totals R7: 619 R8: 0 R9: 5137.4
Rin:1500 Rout:1500 -db:-6.0
R10: 1492.89 R11: 0 R12: 3007.14
E96 R10: 1500 R11: 0 R12: 3010
E96S R10: 1500 & R10S: 0 R11: 0 & R11S: 0 R12: 3010 & R12S: 11.5
E96S Totals R10: 1500 R11: 0 R12: 3021.5
Rin:1500 Rout:1500 -db:-12.0
R13: 4471.61 R14: 0 R15: 2003.17
E96 R13: 4420 R14: 0 R15: 2000
E96S R13: 4420 & R13S: 44.2 R14: 0 & R14S: 0 R15: 2000 & R15S: 0
E96S Totals R13: 4464.2 R14: 0 R15: 2000
Rin:1500 Rout:1500 -db:-24.0
R16: 22273.4 R17: 0 R18: 1601.02
E96 R16: 22600 R17: 0 R18: 1620
E96S R16: 22100 & R16S: 442 R17: 0 & R17S: 0 R18: 1620 & R18S: 0
E96S Totals R16: 22542 R17: 0 R18: 1620
Rin:1500 Rout:1500 -db:-48.0
R19: 375283.03 R20: 0 R21: 1506
E96 R19: 374000 R20: 0 R21: 1500
E96S R19: 365000 & R19S: 8870 R20: 0 & R20S: 0 R21: 1500 & R21S: 0
E96S Totals R19: 373870 R20: 0 R21: 1500
Cheers!
Russ
AndrewT
I tried your resistor calculator to produce a 200r output impedance with a 60source and 200out for the first stage and then 200source 200out for the remaining 4 relays. -38.75db in 1.25db steps.
Unfortunately the input impedance drops very low whenever a relay pulls in to start attenuating.
Is there a trick connection that maintains a higher input impedance and still maintain the low output impedance?
Nordic
So, uncle Russ, will you be selling pics loose then?
Allthough I'd probably wait for the integrated Rev C (Rev D?).
As my current Rev C's weakpoint is the pot I'm using... its a massive step up financialy to get a good pot. In fact a good pot costs as much as the rest of the components combined.
Russ White
Use a buffer in front of the attenuator. ;)
Alternatively using a higher output impedance will bring it up to a much more managable level. A value of 800R to 4K output impedance resluts in generally acceptable values, and sounds great. The values you used are quite low.
Russ White
quote:
When I say integrated REV C, what I mean is power amp and attenuator in one box. no preamp. Same REV C circuit.
I think we could arrange for you to get a PIC when we get things into production. For now, if you are wanting to try this soon, you might see if you can etch the programmer, (actually you could build it on protoboard) and order some for yourself. :)
Cheers!
Russ
Nordic
I looked at those programmer links, where does the chip go to be programmed, or is the chips on the boards the ones being programmed?... I'm thinking it was the processor chip on there...
Russ White
The spot on the PCB for the socket is where you put the PIC to be programmed. :) There is no other chip on the PCB, just passive components. Here is how mine looks:
Nordic
I see, thanks, feel more confident now... have one or 2 projects that are 99% done, which I will complete first, but pics seems to be a usefull skill... even saw a flyer a few weeks ago by a private guy that teaches people how to program pics.... been years since I worked with any programming language... think Visual Basic 4 was the last programing package I worked on.
Think I'll go scratch my old hardware pile for a video card or something to rip a D-sub connector from in the mean time.
Duck-Twacy
quote:
Cheers!
Russ
Good plan! I'll take the kit ;)
Hope you will also offer an input selection (partly for balanced, partly for single ended)
Great work.
Russ White
I think I am on the verge of ordering PCBs so I want to run the design past you folks so that I can be sure you are getting what you need (and most of what you want) :)
First the nitty gritty:
1) The PCB is designed for through hole G6K relays, and either through hole or SMD(1206) resistors.
2) Controller is designed to accept input from a single 5-20K potentiometer which is read by the uC's ADC to set the volume. It of course, is not in the signal path.
3) I left .1" ceneterd pads on the controller board so that those who wish can easily create their own firmware(or use mine) to drive auxiliary features. The possibilities here include: LCD display, IR reciever, rotary encoder, mute, startup delays (soft start) for relays, etc...
4) The PCBs are compact at only 1.5" x 4" and stackable (use 5/8" or so M/F standoffs).
We will make alternate firmware hex files available to download on our site.
Here is the attenuator PCB itself:
Russ White
Here is the controller:
promitheus
Looks great!
Will the control board be able to contorl input selection or will that be another project?
Russ White
Looks great!
The source selector we are creating (Darwin) is designed to integrate with this or the kooka, or even this + XBOSOZ. :) and it has its own controller.
promitheus
Do you know when the 2 projects will be ready to order?
Russ White
Well we learned a lot by doing the attenuator which we are taking the opportunity to apply to the source selector. I would expect both in a month or so, and probably faster for the attenuator as it has already been largely tested and firmware is ready to go. Darwin (the SS) still needs firmware and testing.
Cheers!
Russ
phoneisbusy
Very nice Russ. I can almost follow this... ;)
Now for my ignorant question:
Is there only one ADC available on the pic chip used for the controller? Just wondering if a balance pot input could be added and the controller could adjust the values going to the left/right channels. I suspect I'm just making things more complicated for the controller...
regards
Dave
BrianDonegan
Do you mean, adjust them independently, as in a left-right balance control?
promitheus
Just use 2 boards with a balance Potentiometer.
Byrd
I imagine he means attaching another standard pot as a balance control if there is another ADC on the PIC. Assuming this additional "balance pot" is a 5k Pot
When Pot is @ 0 Ohms --- CHANNEL(L) = MainVolume - 6db.
--- CHANNEL(R) = MainVolume
When Pot is @ 5K Ohms --- CHANNEL(R) = MainVolume - 6db.
When Pot is @ 2.5K Ohms --- CHANNEL(R) = MainVolume
Russ White
L/R balance is an interesting question, and one which I had thought about a lot when designing this particular attenuator. The attenuator is not intended to provide L/R balance with single ended use, not by function of the controller, but rather because each relay shares both left and right channels (its a DPDT relay).
Now with two relay PCBs one could easily create a new controller for balanced independent channels (one PCB per channel) and control them from two ADCs. One with standard linear pot, and the other with a center detent linear pot.
You could also use two sets of these PCBs and just simply use one channel on each and use slider type pots to adjust both channels.
I may work on another design with SPDT relays, but thats a lot of relays. :)
Cheers!
Russ
BrianDonegan
Just wanted to be sure it was not a reference to balanced inputs (vs single ended), which it is capable of with simply a second relay board.
Kram
just showing my interest, would like enough parts to make a balanced vol control.
Mark
lgreen
I'm interested in this as a volume control, and with balance if that is possible.
I assume this has some type of PIC that will be programmed? No idea how to do this so would be interested in a full kit.
P. Lambda
I would be interested in the attenuator kit.
Will the controller come already programmed
or will I have to build a separate board to
download the program on the controller chip?
P.Lambda
Russ White
P.Lambda
If you purchase the kit it will come with a pre-programmed PIC. We will also likely offer PCBs with PIC only for those of you who wish to try your own resisistor combinations.
Cheers!
Russ
P. Lambda
Great! I'm definitely interested.
P. Lambda
herm
Definately interested.
BobEllis
Me too.
joster
Put me down for however many it takes to get this going.:D At least one kit version, 4-5 more board sets depending on price.
promitheus
well I need at least 4 volume boards and 2 controller boards.
Also 2 input selection boards.
jajabin
Hi Russ,
What's the estimated price of the kit?
Russ White
quote:
Originally posted by jajabin
Hi Russ,
Brian is working out a complete BOM and pricing all of the components based on volume. I am not really sure. I can tell you it cost me about $40 to build my SE version. The relays cost about $3.25 a pop in small quantities. And they are pretty much the most expensive things in the kit.
Duck-Twacy
Hello Russ,
Count me in for a volume control kit for balanced operation.
1001meier
Hi Russ,
you can count on one balanced attenuator for me.
Alex
moe29
i'll be in for a balanced kit :)
then i can finally package up my BZLS into a decent enclosure!
jajabin
me either, a balanced kit.
Russ, are you going to provide the PIC programming board/Kit?
Variac
Yet another BZLS customer for your attenuator!
That's me!
Nordic
Would it not be possible to make the balance adjustment before the signal gets to the DPDT relay network?
yggdrasil
You can count me in. Balanced kit.
Will be used with the xBosoz. With this pre-amp I want to move to remote-controlled. Input selector button(s), volume buttons, mute button.
I have not decided if I want any buttons on the pre-amp. Will want a display though.
I have read very briefly through the links you posted on the compiler, and pic-programmer. I am familiar with programming, but have not done any pic-programming before, so the environment is totally unknown. It seems I want other control options than you are planning at the moment. What are your thoughts on sharing the source code? (hoping there are a higher level language than the hex-code).
Johnny
Russ White
Sure... Or you could get a piece of protoboard and create a new controller for two relay PCBs individually. Conect signals and GNDs on the two PCBs(this will lower the impedance by half, but that should still be OK) and you will still be fully utilizing both relay PCBs.
I will eventually offer this second type of controller for L/R balance using two relay PCBs.
phoneisbusy
If the cost of the controller board is not prohibitive, would it be possible to use two contoller boards and connect the balance pot between the two volume pots (or perhaps a dual gang pot connected to the controller boards)?
I'm still learning but it looks plausible after studying some schematics from Rod Elliot's site.
I considered the idea of a balance pot between the outputs but I believe that would require a dual gang balance pot.
I'm interested in a set of boards for balanced output if that isn't obvious. :D
regards
Dave
BrianDonegan
I was thinking about a similar approach, but I'm at work, and it made my brain hurt too much. Then I realized I would never really use L/R balance, which made my brain hurt less...
steenoe
I am in for a balanced kit too:)
Steen:)
Edit, I would need everything programmed allready! I have no intention to try and learn all that stuff:D
Russ White
quote:
Steen:)
Hey Steen, everything will be programmed and ready to rock. :)
steenoe
Thats just great, Russ. Its just the thing I have been looking for:)
Steen:cool:
jajabin
Hi Russ,
Are you going to sell the programming board?
Russ White
Hi Russ,
I suppose I might, I had not really considered it. Does any one else want them?
I would be glad to if people really want them.
hayenc
Maybe you could outline what you get with your programming board that we would not get with the PICkit 2?
Russ White
First off I never set out to offer a programming PCB at all. :) But here are a few advantages.
1) It will program nearly every Michrochip flash PIC out there from 8 to 20 pins. It even has DIP switches and a potentiometer to handle some of the more tricky chips.
2) It works with free open source software.
3) It would be a lot cheaper (the PicKit2 is around $50.00).
4) Its a standard design (based on the RCD which is in turn based on the JDM programmer).
5) Its fun to build the thing yourself. :)
I think Brian and I could probably do a kit for less than $25, but I will have to do all the math, but it would be right around there.
Cheers!
Russ
jajabin
$25 is nice....
I think, everyone should have a programming PCB for future upgrade/update....
Henry Pootel
I've done a little PIC programming for my volume control which uses an evaluation board from www.sparkfun.com The board has a litttle prototyping area where I added the VFD, IR and control of the relays. I can program it using the serial port from my PC.
They also have several PIC programmers that are cheap and might save you the work of creating your own... here's a link to one:
http://www.sparkfun.com/commerce/pr...p?products_id=8
It looks like it runs $12.95.
I hope this helps.
BrianDonegan
That looks like a great deal. Would be good to add a ZIF socket, but you could probably just plug one in to the socket they give you.
Russ White
I have yet to price all the components but based on what I know so far I actualy think the price of a complete programmer kit will be a lot lower than $25.
Just wanted to clarify a couple of things. I have used the JDM programmers a lot, and they are great, but they don't program some of the newer chips correctly, in fact they can cause some chips to become un-programmable. The RCD design is much better in that in allows for the new VPP before VDD algorithm.
Also note that my PCB has a 1000uf cap which even with my notebook computer allows for enough voltage doubler high VPP time to progame an 8K flash. Most JDM type programmers will poop out after 4K or so.
Anyway there are lots of solutions out there, many of which will suite this and many other projects just fine.
I have created a double sided layout which is more optimal. I also added a 6 pin SIP ICSP header which would make breadboard prototyping very easy.
I am thinking if we decide to offer these they will probably come with a 20 pin ZIF socket which will save people a lot of grief and bent pins. And maybe even a serial cable.
Note that I make provision on my PCB for PCs with poor regulation by adding R6 which would either be jumpered(normally) or for PCs with poor regulation (very rare case) it can be 200R.
Cheers!
Russ White
The attenuator is called "Joshua Tree"
The source Selector is called "Darwin"
The will stack, and can use the same JT controller PS.
The PCBs have been ordered and will arrive in 2 weeks or so. Tou will be able to pre-order both very soon.
Here is the info for Darwin:
http://www.diyaudio.com/forums/show...2799#post862799
Cheers!
Russ
Russ White
Just to let you folks know that you can pre-order the Joshua Tree attenuator kits/PCBs now. They should be shipping by or before April 10.
Click on "Joshua Tree", and then "order page".
Cheers!
Russ
joster
I would like a subscription to the Twisted Pear project of the month club!
BrianDonegan
n s ;)
GeWa
At the rate these guys are going it will be "Project of the week" ;)
mpmarino
Cheers!
Russ
Hmm. Is it a coincidence that that's my birthday?:clown:
Russ White
quote:
Nope that was the plan ;) :drink:
Nordic
Uncle Russ, just jog my memory, is this integrateable (new word?) with some sort of remote? I realy love the concept, but I'd hate to forego that upgrade path.
Russ White
No need to forgeo anything. As meantioned before the attenuator is designed to be modular. It connects to a controller via the IDC cable. You could control it any number of ways. It would actually be very easy to create an IR remote controller for this attenuator.
You could even just take a 5V supply and wire 7 switches on a chassis and run the IDC wires to the switches. :) Now that would look really silly, but it would work. ;)
BrianDonegan
I'm a big fan of the volume knob (vs rotary encoder), so I'm gonna use a motorized pot that can be remote controlled via an h-bridge. Shoudl be cake to have the remote control the Darwin as well. The real problem is Russ won't stop designing new stuff, so I am having a little trouble actually building anything ;) It's all so twisted...
Page generated in 0.23246693611145 seconds with 17 queries,
spending 0.01980329 doing MySQL queries and 0.21266365 doing PHP things.
