diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
DIY Plate Amp --> Need the Plate!!! - Click HERE for Original Thread
gmikol
Hey all--
I'm toying around with the idea of making a 41Hz AMP2 kit into a DIY plate amp for a DIY sub. The reason I'm lookng is that I've got a dual 4-Ohm woofer, and finding a commercial plate amp that can drive 2 Ohm loads just isn't happening. And I've read plenty of posts that people think that a DIY plate amp doesn't make sense. But I'm gonna do it, as much as for a learning experience as anything else.
Anyone know of someplace I could get a good plate-amp style heatsink extrusion, or something like it?
Better yet, anybody out there got a busted plate amp (with fins) they want to give me super-cheap?
I drew up something and got a quote from eMachineShop, and that was just for a flat plate!!! It would be cheaper for be to buy a brand-new amp and gut it for its plate. And that don't make sense...
Any help is appreciated...
--Greg
acenovelty
Howdy Greg,
How big a sink you looking for?
?"x?"
Where in the USA are you? Shipping is always a big expense.
gmikol
I don't know for sure. The AMP2 (and all the Tripath amps, really) is fairly efficient, but I don't have the exact specs for dissipation in the output FET's at hand. But were talking about a 800-1000VA toroid and PSU, so I figure at least 8x10 in order to have room to mount everything. Maybe as large as 12x12? I don't have any drawings right now, as I'm just in the proof-of-concept stage (i.e. if I can't source the plate affordably, I won't spend much more time pursuing this.)
I'm in Portland, OR area...do you have something to offer?
--Greg
Nordic
Surely you have something like the yellow pages where you live, I'm sure there will be at least one metal supply place in your area in there... The yellowpages is your friend, even more so than google, when it comes to things like this.
acenovelty
Approx. 8"x10" with 1.25" fins, measures .43 deg. C according to Rod Elliott's calculator. Weighs in at 4.5 lbs.
Page generated in 0.024626016616821 seconds with 16 queries,
spending 0.00969744 doing MySQL queries and 0.01492858 doing PHP things.
