diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Soft-start integrated with DC-protection? - Click HERE for Original Thread
darkfenriz
Hi all
Do you think it would be wise to drive amplifier's mains relay so that it is 'open' when charging supply caps or there is DC on amp's output?
Seems to me that relay by-pass resistor should be of very high value, therefore time constant of soft starting must be more than a second for sure.
A possible issue is energy in reservoir caps as well as energy charging at 'failure' state must be low enough to really protect the coil from burning, a possible benefit is no relay in audio path.
What do you think?
Anyone tried something like this?
regards
darkfenriz
HELLO
davidsrsb
Surely normal solidstate amps will settle without a load to quiescent about as quickly as with.
Obviously single rail amps with output capacitor like the old Quad 303 are a special case.
Algar_emi
See my own approach of this problem at: http://www.diyaudio.com/forums/show...highlight=start
AndrewT
Hi dark,
have you used PSUD2 to investigate the startup characteristics of your proposed PSU?
You will find that the smoothing caps are substantially charged in less than 400mS and fully charged in well under a second.
So, to answer your question. If the supply is large then there is some benefit in delaying the cap charging.
If you want the extra complexity you could consider a time delay on the soft start to get the transformer running, then a longer relay time delay to permit a slow charge to the caps. Finally the longest time delay to the speaker relay.
For 300VA and less then soft start relays are not needed on toroids with less than +-20mF.
400VA to 750VA and <+-75mF soft start is usually good enough.
If you go above 750VA and above +-100mF then slow charge may be helpfull.
The problem you are trying to overcome is voltage drop on your mains wiring at start up and fuse blowing.
You can fit enormous T rated fuses that allow repeated start up, but they offer little protection in the event of a serious overcurrent fault eg. my 625VA +-40mF needs T8 fuses on straight mains connection. T6A blew after a few dozen starts over a few weeks of use. But T3A now starts it with only a soft start (resistor + relay)
Finally, I would keep all the mains related components together on the one assembly. Keep the DC block with the soft start, spike absorbtion and bypassing.
darkfenriz
Big thank you guys
best regards
p.s.
quote:
PSUD2
What's this?
AndrewT
has your search button stopped working?http://www.duncanamps.com/psud2/index.html
darkfenriz
Page generated in 0.026571989059448 seconds with 17 queries,
spending 0.00827241 doing MySQL queries and 0.01829958 doing PHP things.
Please support our sponsor.
