diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
So, what exactly does a compression chamber do?? - Click HERE for Original Thread
NV&H
Can someone please explain the theory and function of a compression chamber? Why do horns need them?
GM
Greets!
Well, first and foremost, it protects the very fragile diaphragm if required. Second, it keeps the driver from comb filtering with itself. Third, it can be used to reactance annull the horn (apply the right amount of acoustic compliance to offset the horn's air mass loading) to obtain peak performance down to Fc.
GM
mwmkravchenko
In a rear loaded horn the compression chamber acts as a capacitance to create a high pass filter if used as a chamber behind a driver that has the cone radiating into the air.
A capacitance blocks low frequencies at the rate of 6db/octave below the corner frequency. The corner frequency is determined by the size of the chamber.
Mark
Page generated in 0.030038118362427 seconds with 16 queries,
spending 0.01714230 doing MySQL queries and 0.01289582 doing PHP things.
