| Super Leach power amplifier for sale - Click HERE for Original Thread |
| supernet |
I am selling a very known Super Leach power amplifier. The amp is a very rubust design and very good sounding too. It has some of the most powerfull and tuneful bass extension compared to other designs.
This is not surprise, due to 8 transistors per channel and huge power supply.
You can read more here:
http://users.ece.gatech.edu/~mleach/superamp/
My amplifer consist of 8×10000uF (100V) proffessional grade caps and one 1200VA toroid transformer. For protection it uses soft start unit with small bulb and powerfull relay. For DC protection and delay I use device kit from Vellemann, but with 16A relays.
It will produce around 270 watts RMS per channel on 8 ohm load.
It makes also very fine visual appereance with 1 and 2 cm thick alluminum front plate.
It is in perfect working condition waitting for new happy listener.
The price is modest: 250 EUR + post costs
email: mark909@gmail.com
P.S. For countries that have not 230V voltage is possible to send amplifier without the transformer. |
