diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
What to do with FE103S, except horns? - Click HERE for Original Thread
Tubes4e4
Gentlemen,
sorry for x-posting / re-posting my question from the general loudspeaker sub-board to here, but it was suggested to do so, since the question is in re a fullrange.
I am wondering if it would make sense to run an ACR / Fostex FE103S down to, say, 70-80 Hz or something and add a sort of subwoofer (for each box). Sort of 2-way speaker with low x-over frequency.
Except kepa1, has someone done this before and/or good suggestions?
Thank you,
Tom
jsdiy
The recommended fostex BR enclosure works fine when a subwoofer is added.
Moreover, if you have two amps, you may go with a multiamplified system by adding a simple passive line xover (1 pot, 2 resistors and 2 cap, see for example here ). A simple but efficient system that I have had, IMHO.
JS
Godzilla
http://www.zillaspeak.com/ZillaSpea...x103-RS1197.asp
Some ideas here...
Page generated in 0.018457889556885 seconds with 17 queries,
spending 0.00778413 doing MySQL queries and 0.01067376 doing PHP things.
