| commstech |
| I built a pair of mono-blocks from UCD180. Was considering to build dc protection for them -- the question is, is it really necessary? |
| Leeuwarden |
| Only when the UcD fails.... :bigeyes: |
| indoubt |
Not with every failure of the UCD there is DC on the output. They seem to be pretty reliable anyway.
Not much failing UCD's either on this board or on the others that I visit. And yes, I'm searching cause I'm building a dual mono version and, for now, without DC protection. |
| Leeuwarden |
| Indoubt, are you looking for a protection design? (Of begrijp ik je verkeerd?) |
| indoubt |
Noop,
I think I do not need one but am investigating whether my perception is correct. Until now i've found remarkable little instances of DC on output related failures
Don't get me wrong, I think it is in general a good idea and the Hypex implementation in their HG supply looks great. I will use 140.000uF per channel (Nippon Chemicon, I think you use similar ?) and can therefore not use this supply (or I will have to throw away the cap's and that is a very expensive solution with double mono) |
| Leeuwarden |
| I'm using my UcD 400 without protection as well. For my UcD400 I use 40.000 uF per channel (Nichicon), why do you want to use so much capacitance? |
| indoubt |
Just because I can :)
I have them available from a never finalised Pass Labs Aleph X project, I will only use half as I have approx 560.000uF available. I will try 40.000 uf Slit foils per channel as well but most extreme amplifiers have ussually an extreme overload on capacity. I acknowledge that UCD's have less capacity requirement as conventional designs, at least in theory but they also seem to benefit from overdesigned PSU's. I will use UCD180AD with two 250Va schuro high end transformers.
With regard to DC protection, I have not found any sign from correct implemented UCD's with DC on the output, at least on the forums that I visit. |
| Leeuwarden |
Haven't found any signs of DC either. I think it is important to use the stand-by switch for plop-free on/off switching.
What kind of rectifiers will you be using? |
| indoubt |
HFA 08 PB 60, these are 8A, 18 nanosec. They might be too light for the UCD400, I will use a softstart and probably heatsinks on the rectifiers. In principle the 8A should be sufficient but the UCD can draw 10 max. Withouth the softstart the giant caps could also draw more than 8A on startup so with softstart and heatsink Í think it's safe. If not I replace them by 25A types but they are slightly slower.
I think we are floating off topic, although the topic starter might benefit |
| Leeuwarden |
| You're right, thanks for the info. |
| commstech |
| quote: | Originally posted by indoubt
Hmm..maybe my main concern is how reliable these modules are...so that i can have no protection at all , and use them with ease. |
| commstech |
I think we are floating off topic, although the topic starter might benefit | yes, i do appreciate the additional useful info. thanks.
it seems to me that many have implemented their UCD amps without the protection....looks like they should be very reliable. maybe i am just a little too worried unnecessarily. |
| Leeuwarden |
Commstech,
Are you planning to use your UcD in an active system? In that case protection is a bit bigger issue I think... |
| commstech |
| quote: | Originally posted by Leeuwarden
Commstech,
exactly what do u mean by active system? |
| Leeuwarden |
| Using multiple amps for one speaker without the use of a passive filter. (But with an active filter) |
| commstech |
Not at all. they are used to drive passive speakers, one amp per channel. |
| Leeuwarden |
Okay, for what it's worth: I drive my (passive) speakers unprotected. I think it is always better to use protection but the UcD is a very good amp and very few have failed. So I guess it is up to you if you want to use protection.
If you want I can provide a link with a design and PCB layout.... |
| classd4sure |
Let's just not kid ourselves and be real clear here.
What we're doing is gambling, so the robustness of the module does make for favorable odds, then comes the big "if". What do you stand to lose "if" your house catches fire, weigh that up against the cost/effort required to implement DC protection and then you can decide if it's worth it for you, or maybe you're not that big on gambling in the first place. Of course "you'd" never leave the amp enabled unattended, someone else might.
Personally my speakers are fused so I don't really care. |
| Leeuwarden |
Yep, were gambling allright. Makes live more exiting :D
Let's talk about protection. The subject has passed many times and I'm still confused.
Let me start by telling that I'm not an expert in electronics.
Okay, dc-protection:
There are, as far as I know, three options:
1 a relay in the speaker output. (probably the most common one)
2 relays between the powersupply and the amp module (like Hypex)
3 fuses at the speaker output
Could you please tell me about the pro's and cons of the above mentioned protection methods? |
| Bgt |
| would never trust electronics, I always use DC protection(fast acting relays). Speakers are far more expensive than amps. |
