diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
3rd order HIgh pass filter - explanation? - Click HERE for Original Thread
APaddy
hi guys
can anyone give a detailed description of what a 3rd order high pass filter is???
what is the 3rd order part ???
and also how to calculate the cut of frequency???
thanks guys
richie00boy
A high-pass filter lets the highs pass and attenuates the lows.
The filter order represents the number of poles in the system. Basically the higher the order the steeper the cut-off slope.
I don't have the formulas to hand, but you should be able to find them in books such as Don Lancaster's Active Filter Cookbook (assuming an active filter).
APaddy
thanks richie00boy for clearing up the 3rd order explanation!!
does anyone know a good website for this stuff...?
need this info for my project report!!!
thanks
AndrewT
I think ESP has a couple of sections on active filter cutoffs and poles(slope), maybe also passive?
http://sound.westhost.com
For passive try Nelson Pass at http://www.passdiy.com
APaddy
thanks andrew
will check em out!!!:D
Ouroboros
Download 'Filterlab' from the Microchip website. A wonderful little program for filters up to 7th order.
phase_accurate
Another way of expressing this is: The order is the same as the amount of components that show a frequency-dependant behaviour (i.e. inductors and/or capacitors) in a filter.
Charles
MosfetOwner
quote:
The other people have already answered most of your questions. However, the 3rd order part means that below the cutoff frequency, the level will roll off at 18dB per octave. A first order filter rolls off at 6dB/octave, a second order at 12dB/octave and so on. An octave is a halving (or doubling) in frequency.
APaddy
thanks guys
does anyone have on hand the calculations used to caclulate the cut off and 3 rd order part.
thanks
Cal Weldon
Are you looking for a passive filter calculator?
If so, here's one: http://www.mhsoft.nl/spk_calc.asp
APaddy
ahhh thanks
but i need the manual calculations to work out how i got a 1khz cut off frequency and how i got 18db per octave and a 3rd order from a high pass filter
help anyone???:eek:
richie00boy
What level of study are you at? If you want the calculations for why it's 3rd-order you are looking at A-Level+ maths calculus.
However, if you just want formula for calculating cut-off frequency and Q then it's a lot easier. Have you got a library you can go to and see if they have The Active Filter Cookbook by Don Lancaster?
phase_accurate
This one will give you the schematic diagram and the values. The proposed circuit is inverting however.
http://www.analog.com/Analog_Root/s...ter/filter.html
Charles
Page generated in 0.036094903945923 seconds with 17 queries,
spending 0.01186872 doing MySQL queries and 0.02422619 doing PHP things.
Please support our sponsor.
