| janneman |
| quote: | Originally posted by hjelm
c8 and c7 seem to be shorted? It seems that half the supply is shorted to ground at c7 and c6. I can find a path from the right side of the J1 to the middle pin of J1.
/regards |
Indeed. A suggestion: move R3, C2 to the left of C7, C8. Then run the trace from R4 etc to R3 etc under C7, C8. Then you can vreate a good ground plane for the supply decoupling caps with short tracks.
Of course, a dual layer would make it even easier.
Jan Didden |
