diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Hysteresis for comparator. - Click HERE for Original Thread
W@ldur
I built a comparator using TL074, actually 1/4 of that.
everything works!
when I send audiosignal into comparator, LED will flach according to the signal.
but it flashes too fast. I want it to flash not so much-I want it to work for 30seconds after it has light once.
signal comes for 1/2 seconds, led works for 30secs.
can i do it adding a hysteresis to comparator or I have to add some transistor ana capacitor as well?
Thanx..
W@ldur
peranders
You can build a peak detector.
W@ldur
no need for a peak detektor, I only want short flash into a longer "burning".
time relay or smtg.
jackinnj
hysteresis reduces a comparator's susceptibility to noise, eliminating false triggering.
what you really want to do is add a time constant to one of the inputs of the comparator -- V = E^-(t/RC) -- then you have to figure a way of discharging the capacitor as the input impedance is not low enough to drain it.
take a look at Rod Elliot's VU meter project and you'll get the general idea.
davidsrsb
You need a monostable to stretch the pulses to seconds.
W@ldur
problem solved.
between input and comparator a diode. from comp. input a 47uF lyt. to GND and parallel with it a 100k potensiometer.
really, it works.
it is called signal intergrating or smtnh like that.
Page generated in 0.021985054016113 seconds with 16 queries,
spending 0.00902319 doing MySQL queries and 0.01296186 doing PHP things.
