diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Hawthorne Silver Iris - New OB driver - Click HERE for Original Thread
johninCR
I got a pair of Silver Iris's from www.HawthorneAudio.com on Monday. If you go to the website, understand that it's a work in progress and their great customer service makes up for anything lacking on the web page. The Iris is a 15" coaxial unit with a Qts of .91, Fs 41.8hz, Vas 244L, Xmax 3.45mm and a sensitivity of 95.8db/w/m.
I've been searching for an ideal single driver solution for use on OB and had pretty much resided to the fact that no full ranger was going to provide enough bass on OB.
Boy was I wrong. I've had a modified Ubaffle in the back of my mind for some time and decided to try it with the Iris's. They worked so well that I named them "The Joint Chiefs" in honor of their pentagon shape. At a max depth of only 16" and a front profile barely big enough to fit the driver, my baffle has an expected Fequal of 73hz which I thought would get me some solid bass since it's equivalent to a 5ft by 6ft flat baffle. I still thought I'd need another bass driver for really full bass at the 95+db levels I often listen. Wrong again.
I'm getting nice solid bass into the 30's and that's with the Joint Chiefs on another cab 27" off the floor! eg I love Pink Floyd, but that part of my collection has gone unused since I've been using OB's because I hadn't found the proper OB bass solution. While they may not go deep enough for trance music, if they can handle Pink Floyd with authority, they can play most anything else.
At first I thought the tweeter was going to be a slight problem with a little harshness, but after a few days of playing they have really smoothed out and I really can't find anything that I would consider a compromise. I don't get pure dipole radiation with my baffle, so I get only about an 80% null at the sides, but that is offset by a wider prime area of bass response out front and I haven't noticed any modal problems crop up, so who cares about a perfect figure 8.
The Iris's just as happy with my HT sand amp as they are with my SET amp. I did, however, hear of one problem using a very underdamped PP amp and the cone started flopping around.
They've got nice full clear OB bass right up to 100db. As typical with OB's the mids are as sweet as can be with those crystal clear vocals and dialogue (for you HT fans), plus the high end is detailed and well extended with all the harshness gone after a few days. Did I mention this all comes with that wide open OB sound? In addition the 15" driver launches a big wavefront, so the sound is big and they have a nice rich tonality that the popular narrow speakers just can't duplicate.
This only thing I can think of that might improve them is going active and biamping and time alignment which is already close to spot on with the coaxial alignment of the tweeter.
All I need is 5 more for my HT setup and I'm done, at least until Hawthorne introduces it's bass augmenter for OB use, since I'll need 2 of those for my HT sub.
Anyone who's on the fence about giving OB a shot, this is the driver you've been waiting for. Their supplies are somewhat limited on this initial run, so you might have to wait 6 weeks or so for the next run to arrive if you procrastinate. Plus he's running an introductory special at $139/driver. Those of us who know the owner, Darrel Hawthorne, from over at the Decware forum are snapping them up pretty quick after the first reports came in about how good they are.
Someone asked me in another thread to report on these drivers once I got them and this is a much more reliable "2 thumbs up" than Siskell and Ebert ever dreamed of giving, so all you fence sitters, it's time to find out what the OB fuss is all about without sacrificing your bass.
Scottmoose
Aha! The return of the reasonbly priced 15" Tannoy Dual Concentric! Or, at least, that's what they appear to be going. What a lovely, lovely driver. Perhaps I should sell someone else's soul to get a pair... :D
Seriously though, those things look very impressive indeed. That's a heck of a good price too, especially the introductory one. Providing they ship to the UK, I'm starting to run out of reasons not to buy a couple to play with. My old Tannoys are still in the garage -they need a re-build really, and they're not so good on open baffles, but these could be a good substitute. Thanks for letting us know!
Best
Scott
Magnetar
It sure looks like a re-badged smaller magnet version (weaker chinned) of the cheap Eminence coax to me. Beta 15 Coax
tubesguy
The drivers sound enticing, but could you post a pic of the baffle? I'm having a little problem visualizing it. TIA - Pat
johninCR
quote:
I'm sure Eminence didn't totally retool for Darrel's run, so I'm sure a lot of the parts are the same. The conical horn seems to be different and the modded tweet is world's better than Eminence's old one (I know because I have some). Was there a problem with the Beta15CX, which is now discontinued? I realize these aren't going to keep up with your big horn loaded system, but for under $300/pr plus some wood and an easy build I don't think they can be beaten. I was just expecting decent bass in a single driver OB, but I was quite pleasantly surprised by the SQ. These are the best speakers I've built and the easiest to construct (except for some cardboard OB test baffles). To give you an idea, I've already gotten them to pull the disappearing act, which is no easy task with OB, and that's with only a few days of break in.
quote:
The front baffle is a pentagon that barely fits the driver. The pentagon shaped U baffle in back has a maximum depth of 16". I'm not quite ready to publicize the exact shape of the back of the baffle, but they killed the resonances except when fairly close to the rear wall and some 1/2" open cell foam clears that right up. Pics will be a few weeks once I figure out a heavy stable base and build a pair with some beautiful exotic hardwood I've had curing for over a year.
Paul Ebert
Is there a frequency response graph for this driver? Also, I'd like to know some information on the crossover (order and cut-off frequency).
Looks quite cool, in concept... And the price is good. I'll certainly consider it, though my initial impression is preference for the B200 (augmented with a tweeter as needed). I guess I'm concerned about beaming.
I am very interested in the 15" bass augmentation driver.
Time to add the Hawthorne site to my favorites and check out the Decware forum. Thanks for letting us know.
Paul
Magnetar
[QUOTE]Originally posted by johninCR
Who makes them? Bet it's Eminence - they DO make good drivers regardless. I've been through some speakers and I've been sold on good high efficency coaxials (prefer a 15) for a record 7 months now. ;) The 15CX I heard had a very simular horn but had a TAD 2001 for the tweeter. It was good with the TAD but I think the little alnico Emilar 175 driver is better in the treble. I think that would be a pretty sweet coax for a direct radiator and not a lot of money.
johninCR
quote:
No graphs that I know of. If I ever get around to measuring, it would be with my baffles, but I'm not sure my SPL meter will even measure correctly since it's OB. I read somewhere recently about mics not registering dipoles.
The XO is 2nd order, but I don't know at what point.
I was leaning the B200 route too, but any way you slice it, the B200 requires bass augmentation, and I question the top end too.
Shouldn't beaming be less of a problem with the horn loaded tweeter?
I believe it's at least a few months away. I thought I'd need the augmenters too, all the way up until I put the Iris's in my Joint Chiefs. Without a 5-6ft flat baffle or some form of U baffle, EQ will be required in some form with ANY OB configuration, bass augmenter or not, to achieve a meaningful bottom end with a reasonable efficiency. You can utilize the high Q of some drivers to offset some baffle size, but drivers that can do that below 40 or 50hz are highly suspect in terms of SQ.
One valid approach is what Linkwitz uses. Take drivers with high quality sound and appropriate capacity, then use electronics to shape the response you want. For a cheap minimalist, like myself, that's not acceptable. All we have is our drivers and our baffle. Personally, I want it as simple as possible and the fewer sound sources the better. I've been looking hard believe I've found the ultimate solution, for me. If it takes a tweeter, a woofer, 2 resistors, 2 inductors, and 2 capacitors between my amp and my ears so be it. At least it helps that the tweeter output comes from the middle of the woofer. I tried to take a full ranger (FE206) plus a woofer and only one inductor as far as a could, but this new driver surpasses it by a significant margin in several respects and I haven't begun to tweak my baffle yet.
Paul Ebert
Well, the horn loading should allow for a lower crossover point, so in that regard, yes (assuming this was taken advantage of in the crossover design).
But, a 15" driver has a horizontal polar response that is 3 dB down at 661 Hz and 6 dB down at 1043 Hz (according to my worn copy of The Loudspeaker Design Cookbook).
If you are getting your Joint Chiefs to disappear (did I read you correctly on that?), then, perhaps, the horn loading really does let the tweeter integrate with the 15" to reduce beaming to an acceptable level. That would be exceedingly cool.
Do you notice the treble changing much as you change listening position?
Variac
The Hammer speaker also uses a custom Eminence Beta, but based on the one with a whizzer cone.
I looked into this a bit a couple of years ago, wanting a driver very similar to the Silver Iris , and being desperate enough to consider trying to get a group buy together.
First, Eminence claims to be the largest driver maker around, but I suspect that there is some qualifier limiting it to musical equipment drivers or PA drivers. Regardless, they are huge. They have lots of interchangable cones, magnets, etc. which they can mix and match to create custom drivers. It seems they can also make custom cones, etc. For what you get, they seem to be an incredible bargain.
The Bastani OB speakers use custom Eminence, the Basszilla now uses an eminence Magnum 15 HO. Adire Audio uses the stock version of the co-ax, but they are more tightlipped about the high end horn that they use. Probably the new Eminence, but no sure info.
If you read the Silver Iris web site they say it is an Eminence I believe. It probably really is custom, because from what I read on the Eminence site, they will make you a custom speaker for a minimum order run of 100 drivers. This seems to include some consulting. Another place where some modification is available is avaialable to all is the tweeter horn. This has a standard thread mount and there are a lot of choices out there.
I would sure be interested in possible tweeter candidates such as the TAD 2001 and Emilar 175.
HEre is the Emilar site. I never heard of them! Anyone know how much this driver costs?
http://www.plusoneengineering.com/drivers.htm
Sems like there might not be much of a supply- they say that they are using all their production to make siren drivers at the moment!!
johninCR
Paul,
These don't beam anywhere close to the beaming of my FE206s, but they obviously don't have wide dispersion like a dome tweeter. The XO stuff is beyond my knowledge level. I figure why bother, since I'd go adjustable active XO long before I tried to put one together, although I have wound quite a few inductors for different OB projects.
Variac,
They are definitely custom made by Eminence. I'm not sure about the XO, but the heavy inductors feel pro. I know Darrel has been back and forth with the designer/engineers quite a while and I think they've been through a number of pre-production prototypes before finalizing it. I probably would have jumped on board the group buy, but I doubt if we would have ended up with this quality.
I bought a pair of the Selenium coaxes that PE had for a while to try on OB. The Selenium's aren't junk, but for about the same price after PE's marked up shipping and much heavier Seleniums, the Iris's absolutely blow them out of the water except the equal sensitivity. The build quality is better, the tweeter is worlds smoother and has much better dispersion, and they make real bass with the right baffle. I thought and still think the Seleniums were a good deal, but the Iris is a steal.
I told Darrel I'd give my baffle dimensions to anyone buying drivers in this initial batch. Let me know if you want them. It's likely to be part of a kit down the road, so I don't want to make them public because they include some unique ideas, all of which worked as planned.
Magnetar
quote:
The older (before they got bought out) Emilar 175 with the alnico magnet is very good - I like it better than the TAD 2001 when used above 1k. A used pair should be around $200.00 - the magnet should be recharged for best sound. The TAD 2001's I had weren't anything special - certainly not worth the extra money. If they are priced the same I'd take a fully charged pair of the little Emilars. The Emilar does not like to be crossed over low and will not sound so good if used that way (cross @ 1k or higher). Some say the early 2001 have a thinner, lighter diaphram then the newer version and sound 'better' - I have had both. They are basically the same in my experiance.
I use the Beyma 15DX - It is a serious 15 with a 4.5" voice coil and a 4" (2" exit) large format compression driver for the highs. These are SOTA - The compression driver can be crossed as low as 500 cycles safely and soundly. The two drivers share the same magnet. Biamp, horn load both front and rear and remove the dust cover to be totally blown away. The Beyma sound much like the big 4001 TAD but is less 'in your face' in the treble and very musical in the 800-10K range- It is discontinued but has been replaced with a small format version the 15KX that may even be better for hifi. 15KX
I just found they actually have a real replacement for the 15DX the neonydium 15XA38ND
It looks to be SOTA also ----
Variac
Just when you think you've heard all the options, more great info!
I'm tempted by the Beyma 'cause I have a relative in Spain.
The Silver Iris speakers might be more money than a group buy, BUT all their work seems to have paid off in great sound. To pay a bit extra above the cost of the stock Eminence for a successful custom effort is a VERY good deal IMHO. Basically this IS the group buy.. but easy, and with a predictable outcome.
DrumDude
These look very interesting for a project I'm working on.
http://www.diyaudio.com/forums/show...&threadid=71552
Approx how much room do they need from rear wall in the "joint chiefs" baffle?
johninCR
OB's sound great but I don't think they'll work for your application because with OB's the bass is concentrated on axis. As people dance around the bass would come and go. I think you'd want boxed bass designed for corner placement in order to fully "stimulate" the room. Then use bass traps in the other corners to absorb the excess created at the room mode frequencies.
DrumDude
I was thinking IB subs in attic and play with active crossover 60-150hz. I have never heard open baffle but it sounds interesting. Maybe I will go back to my original plan of 4 way active. and save the OB experiment for another time.
Thanks for your input.
Music makes you feel, but drums make you dance.
el`Ol
As far as I understand it, this is just true for dipoles, not for infinite baffles. But this is something we all can only speculate about, because very few have the room for such a configuration.
Peter Daniel does, I would ask him.
Greets, Oliver
doorman
Isn't "infinite baffle" just another name for a sealed box?
Cal Weldon
Well...
http://www.diyaudio.com/forums/show...9946&highlight=
zygibajt
Very interesting drivers. Thanks for sharing the information.
They are cheap enough to just buy them for trying. I wonder how much will they charge for shipping to Europe.
Now, have anyone comapred these to Tannoy dual concentric, Goodmans Axiom, any of Lowther , Supravox, Fostex?
Any hint how good they are. The more I try diffrent speakers the more I learn there are no cheap but excellent drivers. They might be extremely good for te money, but if they are cheap they are always inferior.. That was in case of Ciare 250, it is good driver for the money but far away from Supravox or Goodmans 201.
Great drivers but too cheap to be top quality and a bit too expensive to just give them a try without hearing any opinion.
I will be very glad to hear somone's opinion comparing them to other, well known drivers.
Bartek
Bas Horneman
Waaaay too much!!! I went to the checkout..just to see..they have a button shipping estimate.
I'd rather take my chances locally with an Eminence BETA15CX.:D
johninCR
Bartek,
The only direct comparison I can make is to the FE206 and the Iris beats it out in every category except maybe in detail, which is very close, and sensitivity which is a push. That was running without braced baffles on the Iris's and the panel vibrations may have smeared the detail enough to make an audible difference. I'll wait to do a good direct head to head until I have proper inert baffles.
I don't know about the Beta 15CX, but the 8CX doesn't even come close and that's ignoring, of course, the obvious difference in being able make bass.
Bas Horneman
Interesting...ok..so maybe I won't take my chances with the 15CX.:D
I am very happy with the Bastanis...but ofcourse would be interesting to do something similar for even less dinero... :)
zygibajt
Thanks,
I'm using FE 206 right now with Aurum Cantus G2Se on top of them with simple 2uF Siemens MKV cap.
The drivers have phase plugs fitted and are painted with dammar. I'm using them in 60L bass reflex enclosure with RL circuit in series with driver.
Do they have less details than FE 206 in te midrange? Are the highs smooth and good quality?
The highs of FE 206 without supertweeter are quite low quality, very dissapointing.
Bartek
bbaker6212
Aurum Cantus G2Si + FE206E and you're using 2uF for the capacitor? That would put your crossover at around 15K 1st order since the tweeter is nominal 6 ohms, so the tweeter is still adding significantly down to 10K and below! That is way too low. The FE206 already has a rising teble response in this area. I did the same thing, adding the G2Si to my Decware HDT speakers w/FE206E's and used ~1uF which puts the crossover at about 25K but with plainly audible output. It adds just the right amount of air without increasing the brightness already there on the FE206.
http://www.decware.com/cgi-bin/yabb...;num=1126166044
zygibajt
Sorry I'm using FE 204 , the older version of FE 206. The frequency is not that rising in the highs and drops rapidly right after 10Khz.
It sounds good. I tried lower value and it didn't work so well.
Bartek
johninCR
Bartek,
If you are using a totally different driver, then why are you asking questions that I already answered with "every category except..." about the 206? If the 204 doesn't have a rising response and rolls off above 10khz, then it's totally different driver in terms of response. They are just both 8" drivers made by the same manufacturer and start with "20". I'd like to hear those 204's though if it's anything like a 206 without the rising response and ragged top end.
zygibajt
It's just they are actually the same drivers. The parameters are very similar and I was using 206E , too. In the same enclosure, actually before I got AC ribbons. I sold 206E and stayed with 204, but to me 204 and 206 is actually the same drivers, they are very very similar. if one doesn't know they are a bit diffrent wouldn't notice the diffrance. I just forgot I'm using 204 and when bbaker6212 asked why am I using 2uF I thought it might be diffrent for 206 but I doubt it.204 is an older version of 206E. 206E is newer, slightly changed 204, they look the same and the specs. are very close. See the PDF.
zygibajt
And 206E just for quick comparision.
johninCR
Bartek,
Are you related to John Kerry? Flip flopping all over the place. Same...different....same....
Many of the same parts it seems. Is the cone different? Let's just call them very similar and leave it at that.
I have the FE206e and Silver Iris, running both in OB alignments and I stick with my original comparison.
zygibajt
Sorry to confuse you.
They both have identical cones and whizzers. The baskets are the same , too. 206 has a bit bigger and apparently stronger magnet, and that probably makes it 1db more efficent and makes Qts 0,18 instead of 0,2 in 204, but as I said I consider them to be the same drivers in practice.
I just (after reading the comment about 2uF cap) looked closely at the graphs, especially 10K area and indeed they look quite a bit diffrent there so I thought I might mention this, becouse this might (but doesn't have to) explain the diffrances.
Is that OK with you , now?? :)
So you get virtually NO bass from Fostex. Kind of not fair comparison.
Bartek
johninCR
quote:
I don't think I'd even call a 206 by itself on OB a speaker, more of a midrange/tweeter. It has bass assistance and sounds quite nice actually. I've just grown tired of that top end.
barackuda
i know ... old topic :) but i'm realy interested in the SI 15" driver, and especialy the shiping cost to UK.man i'm strugling with the main driver, the Tesla i'm usin sound gorgeous on acoustic music like piano, trumpet, sax, but on louder volumes and with bigger bands its awfull :(
ancient driver, what do you expect.
so the IS would fill in the gap....
any luck on how to get it to UK? does someone have it?
danny
preiter
danny
Why not ask the man himself? www.hawthorneaudio.com
The forum is very active, you will get a quick answer there.
barackuda
shippng to UK is £126 alone, + roughly £160 for both coax's.
the shipping is almost the price of the SI's !!!!!!
thats just woooow...
Rule of the day...... SAVE SAVE SAVE SAVE :D
I have to have them.
Andrewbee
They just announced a new "Sterling Silver Iris". Pre orders being accepted. Its mentioned in the speaker forum on their site. Make sure you are sitting comfortably when you see the price '-)
They may well be worth it, the components used in the crossover are all "boutique"
and Radian compression drivers but they have IMHO taken quite a big step up in the market. I wish I could hear them. If they were a bit cheaper I would probably take the plunge.
Andrew
barackuda
hey guys, i have two of these for sale, here in UK ;)
I mean Silver IRIS, the basic one.
danny.
they sound realy different from classic construction, and can be listened to for a looooooong time.no harsh, no rough uper end.i'm realy satisfied.but unfortunatly i'm going home, so cant take them with me....
Page generated in 0.11843991279602 seconds with 17 queries,
spending 0.01020765 doing MySQL queries and 0.10823226 doing PHP things.
