diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Bipole efficiency - Click HERE for Original Thread
Jeb-D.
What effect does a biplole setup have on efficiency, as opposed to a monopole?
BWRX
It increases it. It has been mentioned in many threads in this forum that the rear firing driver in a bipole effectively gets rid of the baffle diffraction step.
Landroval
How about the difference with bipole drivers wired in parallel and in series?
Scottmoose
Parallel add 3db. Series stays the same.
ScottG
quote:
..depending on the output impeadance of the pairing amplifier.. ;)
Scottmoose
True. But you've got to have some approximates in this life... So I'm told anyway. (I never believed it either!:D )
Best
Scott
Jeb-D.
Thanks for the input. Do any of you guys have any good links to designing a bipole? I have 4; W4-1052's and was planning on making a pair of bipoles.
Scottmoose
Look at Dave's (planet10) two sites: www.t-linespeakers.org and www.planet10-hifi.com
Everything you will ever need, including numerous superb projects -Dave is the Bipole Master as far as I'm concerned.
Best
Scott
salas
dBW you mean, bcs in SPL things are different. Here we have corelated sound sources in close proximity. I have measured a +5 dB average up to 1.5 kHz. This means practically full BSC compensation. Good for listening away from walls. Best FR drivers for dipoles are the ones which exibit a naturally rising response.
See manufacturer's curve of single and then its bipole application here
salas
*for dipoles = I wanted to type 'bipoles'
rcdaniel
Hi all
Would series connection of say 8 ohm drivers (to provide 16 ohm impedance) still not provide the 3dB gain if I changed from 8 ohm to 16 ohm output taps?
I will check out Dave's site as well.
Cheers, Raymond
salas
It will stay where the single 8 Ohm driver is. Your cone travel is going to be half for each driver for same SPL as before. So you gain in THD. You are going to feel it more dynamic.
rcdaniel
That was fast! Thanx Salas.
Kind regards, Raymond
Page generated in 0.03066611289978 seconds with 17 queries,
spending 0.00924706 doing MySQL queries and 0.02141905 doing PHP things.
