diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Carver problem - Click HERE for Original Thread
bill curtin
I have a CARVER TFM 15 that takes approx. 30 min. after turning it on to produce any music. I also have a CARVER Holographic T-6 that is no longer holographic. When the holographic button is depressed it picks up a radio station in the background. Does anyone have a fix for these problems? Appreciate any info! Thanks.
anatech
Hi Bill,
Does your amp go "click" about 5 sec after you turn it on?
Did you mean a CT-6?
I used to be factory warranty for Carver in Canada. I may be able to help you through this.
-Chris
bill curtin
Thanks for your quick response Chris. Yes I did mean CT-6. And yes i do hear an audible click after 5 sec.
anatech
Check the relay contacts.
-Chris
bill curtin
I will try that Sat. Thanks.
anatech
Cool, let me know what you find.
To check, take the cover off and locate the relay. Turn the amp on and after it clicks, give it a tap with a non-conductive, small object (not a plastic hammer or a bat !!;) ). The volume should be a medium to low level.
Do this only if you are experienced working on sound equipment. Have someone present to render aid if you shock yourself.
-Chris
Antonix
I have a Carver TFM 15, I have upgraded it with very satisfaction.
Do you have the schematics of your carver TFM 15 ?
Page generated in 0.023375988006592 seconds with 16 queries,
spending 0.00816607 doing MySQL queries and 0.01520991 doing PHP things.
Please support our sponsor.
