diyAudio.com diyAudio Forums Archive > Top > The Moving Image > General Video
dvd player repair - Click HERE for Original Thread
kalik34
i have a panasonic dvd/cd player S25u, which freezes every few minutes when playing dvd,s. I have cleaned the lens and catriidge tracks. What else can i do to get it functional.
Thanks,
Kalik34
snortonnorton
i would just go diving, fishing, or plain relaxing at the nearest tiki bar on the beach.
man i'm so jealous of where you live.
DigitalJunkie
It seems fairly common that the caps in the power supplies go bad after a while.
I have a cheapie $40 DVD player that was fine for a month,then started skipping and freezing..
One of the electrolytics in the PSU was buldging!
Same with an Apex player I have here,power supply caps.
But I think it needs a cleaning also,it's still being kinda funky at times.
Replace the filter caps,and maybe add a bit more capacitance,if you like.
jean-paul
Maybe Kalik34 invites you to come over for diving etc. if you do the repair ;)
doublejack
You'll get no sympathy from me. Try living in Michigan. We're expecting 5-7 inches of snow overnight, and then I get to shovel it clear in the morning :bawling:
Regarding the original topic, it could be a fault in the power supply someplace as was mentioned, a laser problem, or the motor that spins the disc could be failing.
Is this a DVD changer or otherwise expensive player? I ask because these things are so cheap now it may not be worth the effort to try fixing. I know locally I can get a really nice progressive scan player for $40, and a cheapo model for half that.
Page generated in 0.029298067092896 seconds with 17 queries,
spending 0.00899386 doing MySQL queries and 0.02030420 doing PHP things.
Please support our sponsor.
