diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
help with design SPL box (subwoofer T\S data inside) - Click HERE for Original Thread
Astro Power
Hii all...
I have power acoustik SQ-12 subwoofer...
i want to build the best box for this sub....to get the maximum.
the T\S parameters :
12 inch subwoofer
2' dual 4 Ohm Voice coil.
600W rms
SPL_____92dB
QTS_____0.4546
QES_____0.49
QMS_____5.82
VAS_____1.52 Cu. Ft
FS______32 Hz
Xmax____0.36 inch
it is for my vehicle..
my size limit of the trunk is :
width: 35.43 inch
height: 19.68 inch
depth: 19.68 inch
thanks
tamir
Volenti
1.8cuft, port 4'' by 9'' long. street boomer (performance)
1.8cuft, port 4'' by 18'', SQ, bass extension.
1 box with 2 port choices, you can choose whichever works best:smash:
[edit] ultimate spl option; Bandpass.
rear (sealed) chamber 0.7cuft, vented chamber 2cuft, port 6'' by 4'' long, sub is mounted with the magnet in the vented section (cooling), note this is an SPL only option, ~6db louder than the street boomer, will sound very one notey/boomy with music.
Astro Power
thanks !! in the end of the building i will put some pictures of my work !.
edit: how u desing this box ? with winisd?
tamir
Volenti
BassBox Pro, commercial software with more features than winisd, I use it fo my work.
Page generated in 0.022205114364624 seconds with 17 queries,
spending 0.00889659 doing MySQL queries and 0.01330853 doing PHP things.
