| Single ended classA with dual supply rails - Click HERE for Original Thread |
| boxedin |
hi all,
Is there a schematic for single ended Class A with dual supply rails?.
Let me know.
Alexk |
| Netlist |
One of the most popular is the AlephX. You really have to come over to passlabs forum. :)
/Hugo |
| pinkmouse |
| Or stay here and look at the Krell Clone thread. It's not single ended but it is a cracking amp. ;) |
| gl |
And let's not forget the Alephs on the passlabs site.
Graeme |
| boxedin |
I forgot to metion i need a circuit based on bjt single ended with dual power supply rails.
PAsslabs are FET based. |
| mlloyd1 |
on one of the passlabs sites is a project from 1977 that sounds like it matches your needs. it's an project from the now defunct "Audio" magazine. the entire article is available as a pdf.
mlloyd1
edit: i found the link:
link to single ended class a amp
| quote: | Originally posted by boxedin
| gl |
How about the A25 on the passdiy site then.
Graeme |
| boxedin |
That is diffrential input stage not single ended. :@
It seems like no one has buit an single ended class A amp with dual rails without feedback. |
| gl |
Hi boxedin,
In my view, a single ended amplifier refers to the output stage. I realize that others may hold a differing view.
I consider the A25 to be a single ended class-A BJT amplifier. I can't think of another recommendation offhand but there must be one.
I think you may have to design up something for yourself. How about grafting the front end of the JLH onto the output stage of the A25?
Graeme |
