diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Help with first sub - Click HERE for Original Thread
tivo1
Im building my first sub.. whoohoo
I have an older Shiva MkIII Stats can be found here:
http://www.adireaudio.com/Files/cut...%20Brochure.pdf
I'd like my sub to be 142.5 Liters, with a 4in flared port 12 inches long.
Id like the sub to be downward fireing, and have the port mounted on the bottom also.
I have a PE 250W plate amp, that i would like to include mounted to the box.
Im somewhat lost on how to build the box, size wise, and bracing really confuses me..
I was hopeing someone could help me out.
simon5
First, your port center tube is 12 inches long, but with the flares it will be 18 inches long.
Adire Audio got plans to build that box. You can follow the plans. It's quite a big box, 22.5 inchex x 22.5 inches x 26 inches.
If you don't have the plans, I can send them to you.
To include the plate amp, you need to modify the plan a bit, you cut a hole in one of the sides, between two braces, to include the plate amplifier there.
tivo1
That would be great, As i didnt see any plans on their site.
email is at hotmail.com
unix_fun
Thanks alot!
simon5
Email sent.
If you have any other questions on the plans or anything else, just ask us!
Good luck in your project.
gala
I would like those plans too. E-mail is gala_dragos@yahoo.com .
Page generated in 0.020884037017822 seconds with 17 queries,
spending 0.00783658 doing MySQL queries and 0.01304746 doing PHP things.
