diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
desing +/- 70v 5A power supply - Click HERE for Original Thread
fity
first excuse me for my english.
I need a desing of +/- 70v 5A power supply for a power amplifier.
I have a toroidal transformer 50+50v . may be help me? filtred and if posible regulated.
thanks
edl
regulated won't works, the sec voltage of the trafo is too low, you may need 2*60-70V for that. Anyway regulated voltage is not needed to feed an amp in most cases.
So you need a 25A graetz-bridge, and two 10000uF/80V cap. That's all.
fity
is better to put 4 x 4700uf 80v caps? or more.
Eva
Using more capacitance reduces voltage ripple. On the other hand, using more capacitors of a smaller value (yielding the same total capacitance) may sometimes improve performance if the combination produces less ESR and ESL (equivalent series resistance and inductance) or features a higher total ripple current rating in comparison with a single capacitor.
fity
is this a good desing of power supply for power amp?
is too big the capacitance of caps than the only 10000uf ?
anything changes in this desing?
i need help
Page generated in 0.017544984817505 seconds with 16 queries,
spending 0.00671840 doing MySQL queries and 0.01082659 doing PHP things.
Please support our sponsor.
