diyAudio.com diyAudio Forums Archive > Top > Source > Digital
High resolution (sa)cd output - Click HERE for Original Thread
aaronboumans
I was thinking;
Does anyone have any experience in modding a sacd-player so that it would have a high res. digital output.
I know Oehlrich has done a terrific job on a pioneer 575a but it only does 88.2khz. I would like a 176.4khz output.
So I have the follwoing suggestion;
Take a sony xe-670 which has dsd1702 dac. Now take a pcm4204 (or maybe sm5819) and convert dsd to pcm and then to aes/spdif.
The dsd1702 and pcm 4204 are both from TI's Burr Brown so maybe they have the same dsd input-format?
Anyone any experience with this? Anyone interested in doing so?
Maybe someone (in the Netherlands) would like to help or try with me?
aaronboumans
again, nobody?
rfbrw
The PCM4204 will only convert DSD to the base rate which is 44K1.
aaronboumans
I have read the pcm's PDF again and I now know this
DSD input is 64fS (64x44.1=2,8224Mhz which is the SACD freq. This is also the DSD freq that the dsd1702 accepts, must be correct :rolleyes: ) This is called dualrate. And according to page 16 of the pdf; the dual rate mode is utilized for sampling frequencies higher than 54kHz and up to 108kHz. So max will be 88,2kHz stereo:(
Conclusion; it is better to use oehlrich's pioneer-output:) :angel:
rfbrw
Oehlrich's board assumes you have internal DSD to PCM conversion and you will not get 88k2 out of the PCM4204. You would be better served by the NPC SM5816AF.
aaronboumans
according to;
http://www.npcamerica.com/Datasheets/SM5816.pdf
page 3 suggests that one can convert dsd to pcm with 8fs 24/32bit
8fs=8x44.1khz=352.8khz
hmm can this be something?
Thanks rfbrw, I will look into it. Anyone else any suggestions?
rfbrw
All you have to do now is get the chip.
aaronboumans
this can be difficult I suppose?
rfbrw
quote:
It has been that way in the past but you could give these guys a bell. http://www.kagaeuro.com/npc.html
dorkus
fascinating chip, that NPC. i wonder how the decimation filters sound. i suppose if you had the know-how you could feed it your own coefficients.
if i were able to build my dream all-digital stereo system, i would use that chip so i could perform DSP on DSD. :) i guess you will never see a commercial product with high-res PCM out on SACD tho, due to copyright restrictions. i hate sony. :sigh:
proengin
The closest DSD-PCM product with 176.4KHz and 192KHz SPDIF outs is from DVDupgrade in Swiss.
http://www.dvdupgrades.ch/150019/Mo...tput_board.html
Have anyone tried this? I want to send them one of my old SACD player to get modded.
aaronboumans
to expensive of my taste:dead:
And not DIY enough:D
so I will continue my quest...:rolleyes:
rfbrw
for the Holy Grail ?
aaronboumans
That I allready found, was fairly simple
no, just so I can process the dsd signal in pcm-dsp's. I need a very good source for my 3-way Aleph/ScanspeakRevelator system.
DVD-A is no option because of lack of software, sacd I have plenty!
rfbrw
As I suggested before, give the Kaga peoplle a call, they may be willing to sell to you and not insist on large minimum order.
aaronboumans
Ok I will do that, does anybody else seen one?
hwb
Hello!
I know about a modified DV-668 with the PCB from dvdupgrades.ch.
Ordering procedure was horrible, but the board arrived within a few days. Installation was simple with the right equipment (smd workplace with microscope). Digital audio performance for DVD-Audio is slightly worse than a modded DV-575 (!), due to the lack of a measurment SACD there were no measurments for converted DSD.
The kit is in my eyes too expensive for its performance, I'd rather get a DV-575 or equivalent and mod this one if you can do without 176.4k.
Holger
aaronboumans
I will order from Oehlrich as soon as I received a creditcard. As I understand he has no other way of payments than paypal (you need creditcard). When I have something new I will report here.
Thanks!
Page generated in 0.038345098495483 seconds with 17 queries,
spending 0.00769377 doing MySQL queries and 0.03065133 doing PHP things.
Please support our sponsor.
