| chipco3434 |
I have a couple CD players I have been swapping in the effort to find one that doesn't skip at high volumes...
Old Sony... the worst
Pioneer 5 disk player... so so
Some Technics 100 disk thing I stole from my son... as bad or worse
I have tried several strategies of foam, bricks, tennis balls with little objective results.
Best so far... by a major factor is an A-Open 32X running off an AT power supply. Ugly, but when you want a lot of music, it is less susceptable to skipping at high volumes.
I would invite any recommendations for a more robust and less vibration prone CDP. |
| analog_sa |
Are you running a dance studio? I've never witnessed volume related skipping on my Teac P-700 and don't believe it's even possible with this unit.
Of course you shouldn't delegate vibration isolation to just the cd player. Are you using a rack/support with any abilities in vibration control? Cones, ball-bearing, air-isolation? I suspect not if you get to extremes such as skipping. |
| chipco3434 |
| I'm not running a dance studio, but sometimes I like to heat it up a little. Just a LM3875, two line arrays, and two Tuba18's with 100 watt plate amps. |
