diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
A challenge for the brave! - Click HERE for Original Thread
Kennmunk
I am new to DIY speakers, but I think I understand the basic principles of a subwoofer.
I want to build an active subwoofer, and as I see it. An active subwoofer consists of 3 key parts.
- An amplifier with filters and boost
- A woofer
- And a box.
I will primarily use the sub for a large home theater system, but it should also be able to play music with out sounding booming.
In the ideal situation you would by identify the 3 parts before you by them, so you know that they will give a descent result.
I on the other hand already have 2 of the parts:
- A beyma
18G50 http://www.usspeaker.com/beyma%2018G50-1.htm
- A sub amp SAM-2 http://monacor.com/de/FLE/SAM2.pdf
see page 7-9
My question is: What box should I build to make a decent sub out of the above components?
The maximum size of the box should be 0.8 meter * 0.6 meter * 0.5 meter and it is not a problem if it is smaller
I would love to hear some suggestions
David Gatti
Download Unibox or WinISD, and experiment with some different size boxes, sealed & ported.
Cal Weldon
David is right,
You can dowload it here
http://www.linearteam.dk/default.aspx?download=winisd
Go to the box in the lower right and download winISD
Cal
noah katz
Make sure you get the newer WinISDPro
Page generated in 0.024327039718628 seconds with 17 queries,
spending 0.01011229 doing MySQL queries and 0.01421475 doing PHP things.
Please support our sponsor.
