| JasonL |
Well as im putting more parts on my aleph p 1.7 preamp ( balanced board.) im noticeing that there is no conections for rca normal line in.. what do i do. do i have to build a circuit that converts rca level to balanced. or am i missing something.. i have the boards from kristian.
Help. pweeese |
| Coulomb |
Tie the Negative in on the xlr to ground and use the positive as Centre Pin and the other two as Ground I believe. You can even put a switch in circuit to toggle back and forth.
Anthony |
| Peter Daniel |
Jason,
You started the most informative thread about balanced line and you still in doubts?;)
Coulomb is correct, I think?;) |
